[Qgis-user] moving features in multiple layers at once by mouse
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Tue Aug 11 07:49:49 PDT 2015
Hi Richard,
In Mapinfo there is a similar functionality but not across multiple layers.
TAB file supports multi geometry so when you move a node in common between a
line and a polygon from the same layer for example, it moves both in one
go.
Both the one in MI and the one you mentioned are very useful functionalities
and good additions to the core digitising maybe.
Cheers,
Saber
-----Original Message-----
[mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Richard Duivenvoorde
Sent: 11 August 2015 15:39
To: Qgis-user at lists.osgeo.org
Subject: [Qgis-user] moving features in multiple layers at once by mouse
anybody aware of functionality to edit (selected) features in different
layers?
Usecase:
- having a polygon layer plus a point layer (every point = a testpoint IN a
polygon in the polygon layer)
- using the Multiple Layer Selection-plugin select a polygon + the
correspondig point (in 2 layers)
- when moving the polygon (just by edit tools, like moving it 50 meters to
east) it is needed that the point moves exactly the same distance and
direction
see this as a sort of spatial relation, those polygon+point should stay
together...
Idea's?
Regards,
Qgis-user mailing list
http://lists.osgeo.org/mailman/listinfo/qgis-user
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately
by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified
that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out
such checks as you feel appropriate.
If this email contains a quote or offer to sell products, carry out work or perform services then our standard terms and conditions (which can be found at http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf shall apply unless explicitly stated otherwise.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
