[Qgis-user] vector files time manager
Alexandre Neto
senhor.neto at gmail.com
Tue Aug 11 08:46:43 PDT 2015
Hello Pablo,
I think you can use atlas to do what you want.
I would do the following:
- Create a coverage layer (a simple non spatial table) with all desired
dates (you can simply make and import a CSV), it should have a year_field
column;
- Create a map with the desired extention, and use the already created
layer as atlas coverage;
- In the map canvas, style your universities layer with a rule-based
symbology, and set an unique rule with:
"YEAR" >= attribute( $atlasfeature , 'year_field') AND "YEAR" >=
(attribute( $atlasfeature , 'year_field') + 5)
I think you can then export your atlas for each 5 year to PDF or SVG
Hope it helps
Alexandre Neto
Em ter, 11 de ago de 2015 às 16:19, Pablo Medina Lockhart <
pmedinal at ulb.ac.be> escreveu:
> Dear all,
> I have a problem with the (wonderful) extension Time Manager :
> I have a georeferenced database of all European
> universities with their creation date (eg Bologna
> - 1088). I tried to use this extension to extract
> a map of Europe every 5 years (from 1088) in a
> vector format (ideally pdf) : I need this format
> to be able to reprocess these maps.
> Howewer this extension don't produce vector data
> (I have already ask to Anita Graser, she doesn't have solution).
> Do you have another solution to generate vector files automatically?
> Thank you for your answer
> Pablo
> Université Libre de Bruxelles (ULB)-IGEAT
> Tel : 02/650.68.15
> Fax : 02/650.68.30
> Avenue Depage, 30 1050 Bruxelles
> Campus du Solbosch - Bâtiment D
> Université libre de Bruxelles - CP130/03
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150811/54a95551/attachment.html>
