[Qgis-user] QGIS 2.10 + GRASS - changes in behaviour?
    Radim Blazek
    radim.blazek at gmail.com
    Wed Aug 12 02:01:47 PDT 2015
On Wed, Aug 12, 2015 at 5:53 AM, Alex Mandel <tech_dev at wildintellect.com> wrote:
> On 08/11/2015 02:23 PM, Carlos Grohmann wrote:
>> Hi all,
>> After upgrading to 2.10 (running kyngschaos pkgs on OS X), I noticed that
>> the "add grass raster layer" and "add grass vector layer" button from the
>> GRASS plugin are gone. Is this a bug or there were changes in 2.10 related
>> to GRASS layers?
>> Suddenly I can't even visualize my GRASS layers anymore..
>> best
> Well known issue, downgrade back to previous version you had working if
> you need GRASS layers working in QGIS or the QGIS+GRASS Plugin.
It is not an issue, the buttons were removed after discussion on mailing list:
http://lists.osgeo.org/pipermail/qgis-developer/2015-May/037827.html
Layers may be added from browser.
> Expect QGIS 2.12 to likely work with GRASS 7.
> http://www.gissula.eu/qgis-grass-plugin-crowdfunding/
QGIS 2.10 compiled with GRASS 7 can visualize and manage GRASS 7
layers, plugin upgrade is scheduled for 2.12.
> Longer answer the QGIS+GRASS plugin is being rewritten to support GRASS
> 7 which is fairly new. 2.10 is somewhere in no mans land where it
> doesn't work with either 6 or 7 for the plugin
GRASS 6 provider and plugin should work as before, apart that plugin
browser and 'add layer' buttons were substituted by standard QGIS
browser. Have you found bugs in GRASS 6 plugin introduced in 2.10?
The GRASS plugin is not yet upgraded to GRASS 7, but the provider is
already upgraded. It means that people using GRASS 6 can use the GRASS
provider and plugin while people using GRASS 7 can use the provider,
which has much richer functionality, it allows to manage layers
(rename,delete,copy) or import data to GRASS using drag-and-drop,
which supports on-the-fly reprojection or creation of link to external
data (r.external) if CRS are the same (optional) via QGIS browser.
> (The grass functions in
> the toolbox are related only indirectly, so those working combos differ).
What do you mean exactly?
Radim
> Thanks,
> Alex
> Qgis-user mailing list
