[Qgis-user] QGIS 2.10 + GRASS - changes in behaviour?
Radim Blazek radim.blazek at gmail.com
Wed Aug 12 02:06:22 PDT 2015
On Wed, Aug 12, 2015 at 9:20 AM, Jürgen E. <jef at norbit.de> wrote:
> Hi Alex,
> On Tue, 11. Aug 2015 at 20:53:41 -0700, Alex Mandel wrote:
>> Longer answer the QGIS+GRASS plugin is being rewritten to support GRASS
>> 7 which is fairly new. 2.10 is somewhere in no mans land where it
>> doesn't work with either 6 or 7 for the plugin (The grass functions in
>> the toolbox are related only indirectly, so those working combos differ).
> AFAIK the plugin works fine with GRASS 6.  I suspect the OSX package either
> ships with GRASS 7 (hence no plugin), otherwise it might be a packaging problem
> on OSX).
Since QGIS 2.10, the GRASS plugin may be compiled with GRASS 6 or 7 or
with both at the same time (all binaries have different file names for
GRASS 6 and 7). It is on packagers which version(s) of GRASS they
choose. OSGeo4W, for example supports both GRASS 6 and 7.
Radim
> Jürgen
> Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
> Software Engineer           D-26506 Norden             http://www.norbit.de
> QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
> Qgis-user mailing list
