[Qgis-user] QGIS 2.10 + GRASS - changes in behaviour?
Jürgen E. Fischer
jef at norbit.de
Wed Aug 12 00:20:48 PDT 2015
Hi Alex,
On Tue, 11. Aug 2015 at 20:53:41 -0700, Alex Mandel wrote:
> Longer answer the QGIS+GRASS plugin is being rewritten to support GRASS
> 7 which is fairly new. 2.10 is somewhere in no mans land where it
> doesn't work with either 6 or 7 for the plugin (The grass functions in
> the toolbox are related only indirectly, so those working combos differ).
AFAIK the plugin works fine with GRASS 6. I suspect the OSX package either
ships with GRASS 7 (hence no plugin), otherwise it might be a packaging problem
on OSX).
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150812/9a140857/attachment.sig>
