[Qgis-user] Hydrology
Matt Boyd mattslists at gmail.com
Fri Aug 14 01:03:39 PDT 2015
Hi List,
I need to work out some channels and hydrology things from a topography
DEM. I've done a little bit of this before but if there's a how to or a
tutorial on the correct process / work flow that someone could point me at
I'd appreciate it.
Basically I need to work out that if I have rainfall in an certain area,
how much of it makes its way through to another area (using a DEM) and the
path it takes. It doesn't need to be precisely quantified, just an idea on
preferred pathways and the end result.
Thanks
Matt
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150814/e7d275d7/attachment.html>
