[Qgis-user] Hydrology
Werner Macho
werner.macho at gmail.com
Fri Aug 14 01:22:59 PDT 2015
Hi Matt,
You mean something like this?
http://gis.stackexchange.com/questions/68158/how-to-compute-flow-direction-and-flow-accumulation-with-qgis
regards,
Werner
On Fri, Aug 14, 2015 at 10:03 AM, Matt Boyd <mattslists at gmail.com> wrote:
> Hi List,
> I need to work out some channels and hydrology things from a topography DEM.
> I've done a little bit of this before but if there's a how to or a tutorial
> on the correct process / work flow that someone could point me at I'd
> appreciate it.
> Basically I need to work out that if I have rainfall in an certain area, how
> much of it makes its way through to another area (using a DEM) and the path
> it takes. It doesn't need to be precisely quantified, just an idea on
> preferred pathways and the end result.
> Thanks
> Matt
> Qgis-user mailing list
