[Qgis-user] Hydrology
Lene Fischer
lfi at ign.ku.dk
Fri Aug 14 03:14:31 PDT 2015
Hi Matt,
Just finished my lessons at this minute – in Hydrology ☺
We use DTM
Create:
· Hillshade with factor 2
· Use Fill Sinks (Wang& Lui) on DTM
· Create a bluespot in Rastercalculator FilledDEM – DTM. Style and set transparency to 0
· Use Channelnetwork & Drainage Basin to create Watershed basins and Streams (– The factor is set to 5 – if you want a more dense streamnetwork use a smaller factor.)
Style/Graduate the streams by the attribute ‘Order’. Style Categorize the Watershed Basins
Hope these few lines can help ☺
Regards
Lene Fischer
Associate Professor
Department of Geosciences and Natural Resource Management
University of Copenhagen
MOB +45 40115084
lfi at ign.ku.dk<mailto:lfi at ign.ku.dk>
[cid:image001.gif at 01D03029.2F3EC6A0]
Fra: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] På vegne af Matt Boyd
Sendt: 14. august 2015 10:04
Til: qgis-user
Emne: [Qgis-user] Hydrology
Hi List,
I need to work out some channels and hydrology things from a topography DEM. I've done a little bit of this before but if there's a how to or a tutorial on the correct process / work flow that someone could point me at I'd appreciate it.
Basically I need to work out that if I have rainfall in an certain area, how much of it makes its way through to another area (using a DEM) and the path it takes. It doesn't need to be precisely quantified, just an idea on preferred pathways and the end result.
Thanks
Matt
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150814/e4dfe238/attachment.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150814/e4dfe238/attachment.jpg>
