[Qgis-user] moving features in multiple layers at once by mouse
Carlos López PSIG
carlos.lopez at psig.es
Mon Aug 17 01:50:12 PDT 2015
Hi Richard,
You can do this using PostGIS and Triggers!!
Best regards,
* <http://www.psig.es>*
*Carlos López Quintanilla*
www.psig.es
+34 699.680.261
2015-08-17 10:03 GMT+02:00 Richard Duivenvoorde <rdmailings at duif.net>:
> On 17-08-15 09:40, Paolo Cavallini wrote:
> > Il 12/08/2015 09:56, Richard Duivenvoorde ha scritto:
> >> I can think of some plugin which holds a handle to a one of the editing
> >> layers, and listens to the mouse events on that one and translates those
> >> to the other editing layer....
> >> But I was hoping that maybe people already had this..:-)
> > Hi all,
> > I think this should be a core feature; I have been already asked several
> > times about it, hopefully someone will decide investing on it soon.
> > All the best.
> Hi Paolo,
> I think the 'hard'-part would be the UI-side of this.
> As in: if you have three editable layers, which one is 'leading', which
> is to follow and which one should maybe be ignored... Does this need a
> dialog, or is it enough to edit one of the layers, and all editable
> layers just follow, then all editable layers should 'listen' to all
> editable layers....
> Regards,
> Richard
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150817/eedc0793/attachment.html>
