[Qgis-user] [QGIS 2.10.1-Pisa, OSX 10.10.4] Raster colormap does not work
Pieter du Plooy
pjduplooy at zpanelcp.com
Wed Aug 19 03:45:54 PDT 2015
Hi Carlos.
It is because the grass64 that is poured from bottle is linked against an
older libproj. I /usr/local/lib, there should be a libproj.9.dylib which
is the new version. Just do a ln -sf /usr/local/lib/libproj.9.dylib
/usr/local/lib/libproj.0.dylib.
Sorted.
By the way, you have to use grass64, as the grass plugin is still on 6.4.
Have a look at http://www.gissula.eu/qgis-grass-plugin-crowdfunding.
Basically QgsGrassGisLib has not been updated to grass 7 api.
If I remember correctly, this will function properly in QGIS 2.12.
By the way, does your grass7 in processing toolbox work?
For what its worth my QGIS install was done with brew -v install qgis-210
--with-grass7 --with-orfeo --with-qt-mysql --with-r --with-saga-gis
--without-server --HEAD
Pieter
On Wed, Aug 19, 2015 at 12:26 PM, Carlos Grohmann <carlos.grohmann at gmail.com
> wrote:
> Thanks Pieter
> This works, although I installed it with --with-grass7 and end up with
> grass-70 AND grass-64...
> also, when starting QGIS, I get errors about libproj, because of grass-64
> (which I didn't want in the first place)
> >ERROR 1: dlopen(/usr/local/lib/gdalplugins/gdal_GRASS.so, 1): Library not
> loaded: >/usr/local/lib/libproj.0.dylib
> > Referenced from:
> /usr/local/opt/grass-64/grass-6.4.4/lib/libgrass_gproj.6.4.4.dylib
> in /usr/local/lib, the only file for libproj I have is libproj.la
> best
> Carlos
> On Tue, Aug 18, 2015 at 6:23 PM, Pieter du Plooy <pjduplooy at zpanelcp.com>
> wrote:
>> Hi Carlos
>> I just adapted the pull request from christianurich on osgeo4mac. 2.10
>> for github 2_10 branch compiles pefectly. Attached is the rb
>> On Tue, Aug 18, 2015 at 11:17 PM, Pieter du Plooy <pjduplooy at zpanelcp.com
>> > wrote:
>>> Hi Carlos
>>> On Tue, Aug 18, 2015 at 10:53 PM, Carlos Grohmann <
>>> carlos.grohmann at gmail.com> wrote:
>>>> For me, one way to increase the number of testers would be a working
>>>> homebrew formula for the development branch.
>>>> So far, osgeo4mac has formulas for 2.6 and 2.8 (I tried compiling 2.8
>>>> but it didn't worked). home-brew/science has 1.8 (!). So most mac users are
>>>> dependent on Kyngsburie's binaries.
>>>> cheers
>>>> Carlos
>>>> On Tue, Aug 18, 2015 at 5:39 PM, Lene Fischer <lfi at ign.ku.dk> wrote:
>>>>> Hi,
>>>>> If you can set up a scheme with functions and perhaps dataset, I have
>>>>> students who attend our campus for 4 year and who would like to be a part
>>>>> of test team. What we need is schemes...
>>>>> And 40-50 of the students use Mac
>>>>> Regards
>>>>> Lene Fischer
>>>>> Associate Professor
>>>>> Department of Geosciences and Natural Resource Management
>>>>> University of Copenhagen
>>>>> MOB +45 40115084
>>>>> lfi at ign.ku.dk
>>>>> -----Oprindelig meddelelse-----
>>>>> Fra: qgis-user-bounces at lists.osgeo.org [mailto:
>>>>> qgis-user-bounces at lists.osgeo.org] På vegne af Nyall Dawson
>>>>> Sendt: 18. august 2015 21:21
>>>>> Til: John Helly
>>>>> Cc: qgis-user
>>>>> Emne: Re: [Qgis-user] [QGIS 2.10.1-Pisa, OSX 10.10.4] Raster colormap
>>>>> does not work
>>>>> On 16 August 2015 at 16:26, John Helly <hellyj at ucsd.edu> wrote:
>>>>> > Hi.
>>>>> > I've just installed QGIS 2.10.1-Pisa and find that the raster
>>>>> colormap
>>>>> > does not work. I've tested the same dataset on 2.6.1-Brighton and it
>>>>> > does work. Any ideas what might be wrong? This is the distro from
>>>>> > Kyngchaos.
>>>>> This is now fixed in master, and I'll backport to 2.10.
>>>>> However, this issue highlights an important weakness in the QGIS
>>>>> release testing -- we need more OSX testers! This issue should have been
>>>>> picked up prior to release, but we have very few active developers who
>>>>> regularly use OSX. So it's up to you... if you rely on running QGIS on OSX
>>>>> we need your help with testing beta and nightly releases and providing
>>>>> timely feedback so these OSX specific issues can be fixed prior to release.
>>>>> Nyall
>>>>> > J.
>>>>> > John Helly, University of California, San Diego / San Diego
>>>>> > Supercomputer Center / Scripps Institution of Oceanography / 760 840
>>>>> > 8660 mobile / stonesteps (Skype) / stonesteps7 (iChat) /
>>>>> > http://www.sdsc.edu/~hellyj
>>>>> > _______________________________________________
>>>>> > Qgis-user mailing list
>>>>> > Qgis-user at lists.osgeo.org
>>>>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Prof. Carlos Henrique Grohmann
>>>> Institute of Energy and Environment - Univ. of São Paulo, Brazil
>>>> - Digital Terrain Analysis | GIS | Remote Sensing -
>>>> http://carlosgrohmann.com
>>>> http://orcid.org/0000-0001-5073-5572
>>>> ________________
>>>> Can’t stop the signal.
> ________________
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150819/8283909d/attachment.html>
