[Qgis-user] [QGIS 2.10.1-Pisa, OSX 10.10.4] Raster colormap does not work
    Pieter du Plooy
    pjduplooy at zpanelcp.com
    Wed Aug 19 04:51:55 PDT 2015
Carlos.
It looks like colorscales has been fixed in master branch, but is still
being backported to 2_10 branch.
I will probably work, as the install (if you brew with --HEAD) installs
from the 2_10 master branch.
The only caveat is that you will probably have to recompile once a day.
Pieter
On Wed, Aug 19, 2015 at 1:44 PM, Carlos Grohmann <carlos.grohmann at gmail.com>
wrote:
> Thanks Pieter
> Yes, now I remembered this thing with grass-64 and the plugin.
> Installation works. And the bug with colorscales not working on rasters is
> still there. Will the formula work with the latest updates to 2.10? Will
> keep testing it.
> cheers
> Carlos
> On Wed, Aug 19, 2015 at 7:45 AM, Pieter du Plooy <pjduplooy at zpanelcp.com>
> wrote:
>> Hi Carlos.
>> It is because the grass64 that is poured from bottle is linked against an
>> older libproj.  I /usr/local/lib, there should be a libproj.9.dylib which
>> is the new version.  Just do a ln -sf /usr/local/lib/libproj.9.dylib
>> /usr/local/lib/libproj.0.dylib.
>> Sorted.
>> By the way, you have to use grass64, as the grass plugin is still on
>> 6.4.  Have a look at http://www.gissula.eu/qgis-grass-plugin-crowdfunding.
>> Basically QgsGrassGisLib has not been updated to grass 7 api.
>> If I remember correctly, this will function properly in QGIS 2.12.
>> By the way, does your grass7 in processing toolbox work?
>> For what its worth my QGIS install was done with brew -v install qgis-210
>> --with-grass7 --with-orfeo --with-qt-mysql --with-r --with-saga-gis
>> --without-server --HEAD
>> Pieter
>> On Wed, Aug 19, 2015 at 12:26 PM, Carlos Grohmann <
>> carlos.grohmann at gmail.com> wrote:
>>> Thanks Pieter
>>> This works, although I installed it with --with-grass7 and end up with
>>> grass-70 AND grass-64...
>>> also, when starting QGIS, I get errors about libproj, because of
>>> grass-64 (which I didn't want in the first place)
>>> >ERROR 1: dlopen(/usr/local/lib/gdalplugins/gdal_GRASS.so, 1): Library
>>> not loaded: >/usr/local/lib/libproj.0.dylib
>>> >  Referenced from:
>>> /usr/local/opt/grass-64/grass-6.4.4/lib/libgrass_gproj.6.4.4.dylib
>>> in /usr/local/lib, the only file for libproj I have is libproj.la
>>> best
>>> Carlos
>>> On Tue, Aug 18, 2015 at 6:23 PM, Pieter du Plooy <pjduplooy at zpanelcp.com
>>> > wrote:
>>>> Hi Carlos
>>>> I just adapted the pull request from christianurich on osgeo4mac.  2.10
>>>> for github 2_10 branch compiles pefectly.  Attached is the rb
>>>> On Tue, Aug 18, 2015 at 11:17 PM, Pieter du Plooy <
>>>> pjduplooy at zpanelcp.com> wrote:
>>>>> Hi Carlos
>>>>> 2.10 for github 2_10 branch compiles pefectly.  Attached is the rb
>>>>> On Tue, Aug 18, 2015 at 10:53 PM, Carlos Grohmann <
>>>>>> For me, one way to increase the number of testers would be a working
>>>>>> homebrew formula for the development branch.
>>>>>> So far, osgeo4mac has formulas for 2.6 and 2.8 (I tried compiling 2.8
>>>>>> but it didn't worked). home-brew/science has 1.8 (!). So most mac users are
>>>>>> dependent on Kyngsburie's binaries.
>>>>>> cheers
>>>>>> Carlos
>>>>>> On Tue, Aug 18, 2015 at 5:39 PM, Lene Fischer <lfi at ign.ku.dk> wrote:
>>>>>>> Hi,
>>>>>>> If you can set up a scheme with functions and perhaps dataset, I
>>>>>>> have students who attend our campus for 4 year and who would like to be a
>>>>>>> part of test team. What we need is schemes...
>>>>>>> And 40-50 of the students use Mac
>>>>>>> Regards
>>>>>>> Lene Fischer
>>>>>>> Associate Professor
>>>>>>> Department of Geosciences and Natural Resource Management
>>>>>>> University of Copenhagen
>>>>>>> MOB +45 40115084
>>>>>>> lfi at ign.ku.dk
>>>>>>> -----Oprindelig meddelelse-----
>>>>>>> Fra: qgis-user-bounces at lists.osgeo.org [mailto:
>>>>>>> qgis-user-bounces at lists.osgeo.org] På vegne af Nyall Dawson
>>>>>>> Sendt: 18. august 2015 21:21
>>>>>>> Til: John Helly
>>>>>>> Cc: qgis-user
>>>>>>> Emne: Re: [Qgis-user] [QGIS 2.10.1-Pisa, OSX 10.10.4] Raster
>>>>>>> On 16 August 2015 at 16:26, John Helly <hellyj at ucsd.edu> wrote:
>>>>>>> > Hi.
>>>>>>> > I've just installed QGIS 2.10.1-Pisa and find that the raster
>>>>>>> colormap
>>>>>>> > does not work. I've tested the same dataset on 2.6.1-Brighton and
>>>>>>> it
>>>>>>> > does work. Any ideas what might be wrong?  This is the distro from
>>>>>>> > Kyngchaos.
>>>>>>> This is now fixed in master, and I'll backport to 2.10.
>>>>>>> However, this issue highlights an important weakness in the QGIS
>>>>>>> release testing -- we need more OSX testers! This issue should have been
>>>>>>> picked up prior to release, but we have very few active developers who
>>>>>>> regularly use OSX. So it's up to you... if you rely on running QGIS on OSX
>>>>>>> we need your help with testing beta and nightly releases and providing
>>>>>>> timely feedback so these OSX specific issues can be fixed prior to release.
>>>>>>> Nyall
>>>>>>> > J.
>>>>>>> > John Helly, University of California, San Diego / San Diego
>>>>>>> > Supercomputer Center / Scripps Institution of Oceanography / 760
>>>>>>> 840
>>>>>>> > 8660 mobile / stonesteps (Skype) / stonesteps7 (iChat) /
>>>>>>> > http://www.sdsc.edu/~hellyj
>>>>>>> > _______________________________________________
>>>>>>> > Qgis-user mailing list
>>>>>>> > Qgis-user at lists.osgeo.org
>>>>>>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>> Prof. Carlos Henrique Grohmann
>>>>>> Institute of Energy and Environment - Univ. of São Paulo, Brazil
>>>>>> - Digital Terrain Analysis | GIS | Remote Sensing -
>>>>>> http://carlosgrohmann.com
>>>>>> http://orcid.org/0000-0001-5073-5572
>>>>>> ________________
>>>>>> Can’t stop the signal.
>>> ________________
> ________________
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150819/3e0d4d14/attachment.html>
