[Qgis-user] How to display SID raster on QGIS 2.10 PISA Kubuntu 15.04 ?
Pieter du Plooy pjduplooy at zpanelcp.com
Fri Aug 21 08:21:02 PDT 2015
Hi guys
Just a side note on this.  It seems that one can not compile gdal with the
MrSID SDK if your gcc is higher than version 5.
I am however able to compile gdal on linux if gcc is 4.8 or 4.9.
The SDK comes in two versions, one for gcc 4.2 and one for gcc 4.4.
Does anyone know if there is a newer version available?
I am however able to compile the sdk on OSX with homebrew, and kyngchaos
can also use it in his frameworks.
Pieter
On Fri, Aug 21, 2015 at 12:26 AM, Randal Hale <
rjhale at northrivergeographic.com> wrote:
> If you want to you can download the MrSid SDK and uncompress the sids on
> your linux workstation: http://www.lizardtech.com/downloads/category/
> (MrSID SDK)
> I downloaded the SDK (placed it in /home/rjhale/apps and wrote a very
> small messy script that does the following:
> #!/bin/bash
> #set library path
> export LD_LIBRARY_PATH=/home/rjhale/apps/sidgeodecode/bin
> #fix the extension
> file=$1
> newname=`echo $file | sed 's/\(.*\.\)sid/\1tif/'`
> #run the Geodecode program
> /home/rjhale/apps/sidgeodecode/bin/mrsidgeodecode -wf -i $file -o $newname
> It usually takes just a minute or two to uncompress them on my workstation
> - for me a sid that is 400 mb usually uncompresses to 6 GB - with a small
> amount of work (tiling, pyramid layers) it's renders very nicely.
> I agree - building sid support into QGIS is not for the faint of heart. I
> did it once but decided against - I would rather just uncompress them using
> this route and be done with it.
> Randy
> On 08/20/2015 06:06 PM, Bernd Vogelgesang wrote:
> Hi
> Am 20.08.2015, 17:41 Uhr, schrieb Joachim Bergerhoff <agimjo at gmail.com>
> <agimjo at gmail.com>:
> Dears, I guess the message title is explicit enough ?
> BTW, I have downloaded the SDK 9.1.0 from Imtech.  The ReadMe says:
> "INSTALLATION:
>   No specific installation is required to use the MrSID SDK beyond copying
> the SDK contents to your local machine.
>   After installing, we suggest building and running the example program to
> assure correct installation and behaviour."
> But copying the SDK download (unpacked) somewhere on my disk obviously is
> not enough and I am lost when it comes to "building" etc.
> Thanks,
> Joachim
> As far as I know, there is no way, but building your own gdal with mrsid
> support und Linux. The instructions can be found somewhere in the
> qgis-maze, but I don't how up-to-date they are.
> I tried once, but as the instructions were not really idiot-proof and I
> prefer to use repositories, and as there was no clear instruction to be
> found how to deal with incompatibilities, I gave up so far.
> I think the masterbrains just compile everything, and the stupid masses
> use a virtual Windows machine to transform to geoTIFF (like me).
> There was an article mentioned in the list how to produce quite small
> geoTIFF some weeks ago:
> http://blog.cleverelephant.ca/2015/02/geotiff-compression-for-dummies.html
> That's all I can tell
> Bernd
> Bernd Vogelgesang
> Siedlerstraße 2
> 91083 Baiersdorf/Igelsdorf
> Tel: 09133-825374
> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
> Randal Hale
> North River Geographic Systems, Inchttp://www.northrivergeographic.com423.653.3611 rjhale at northrivergeographic.com
> twitter:rjhale     http://about.me/rjhalehttp://www.northrivergeographic.com/introduction-to-quantum-gis
> Southeast OSGEO: http://wiki.osgeo.org/wiki/Southeast_US
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150821/d3087e09/attachment.html>
