[Qgis-user] Issues to install QGIS on RedHat 6
john polo
jpolo at mail.usf.edu
Thu Aug 27 09:23:49 PDT 2015
I found an answer that I assume the original poster Marian came up with
on G.I.S. Stack Exchange. It's here:
https://gis.stackexchange.com/questions/150525/qgis-2-8-starts-with-an-error-and-i-am-not-able-to-run-python-console?rq=1
Her answer worked mostly for me. I am still getting a python error at
startup, but the console works now.
Marian states "... I have also notified QGIS project about the changes
on their code. Unfortunately I did not get any answer from them." I'm
including that with this post to the list in case it makes the fix more
apparent.
John
On 8/21/2015 1:48 PM, john polo wrote:
> I have a similar problem as what's happened to Marian. However, I am
> using CentOS 7, FWIW. I get the same error message at start-up as when
> I try to run the Python console. Here it is:
> Failed to open Python console:
> Traceback (most recent call last): File "", line 1, in File
> "/usr/lib64/python2.7/site-packages/qgis/utils.py", line 478, in
> _import mod = _builtin_import(name, globals, locals, fromlist,
> level) File "/usr/share/qgis/python/console/__init__.py", line 26,
> in from console import show_console File
> level) File "/usr/share/qgis/python/console/console.py", line 29, in
> from console_settings import optionsDialog File
> level) File "/usr/share/qgis/python/console/console_settings.py",
> line 24, in from console_compile_apis import PrepareAPIDialog
> File "/usr/lib64/python2.7/site-packages/qgis/utils.py", line 478, in
> level) File
> "/usr/share/qgis/python/console/console_compile_apis.py", line 28, in
> from ui_console_compile_apis import Ui_APIsDialogPythonConsole
> level) File
> "/usr/share/qgis/python/console/ui_console_compile_apis.py", line 70,
> in from Qsci.qsciscintilla import QsciScintilla File
> level) ImportError: No module named Qsci.qsciscintilla
> Python version: 2.7.5 (default, Jun 24 2015, 00:41:19) [GCC 4.8.3
> 20140911 (Red Hat 4.8.3-9)] QGIS version: 2.8.2-Wien 'Wien', exported
> Python path: ['/usr/share/qgis/python', u'/home/jpolo/.qgis2/python',
> u'/home/jpolo/.qgis2/python/plugins',
> '/usr/share/qgis/python/plugins', '/usr/lib64/python27.zip',
> '/usr/lib64/python2.7', '/usr/lib64/python2.7/plat-linux2',
> '/usr/lib64/python2.7/lib-tk', '/usr/lib64/python2.7/lib-old',
> '/usr/lib64/python2.7/lib-dynload',
> '/usr/lib64/python2.7/site-packages',
> '/usr/lib64/python2.7/site-packages/gst-0.10',
> '/usr/lib64/python2.7/site-packages/gtk-2.0',
> '/usr/lib64/python2.7/site-packages/wx-2.8-gtk2-unicode',
> '/usr/lib/python2.7/site-packages', u'/home/jpolo/.qgis2//python',
> '/usr/share/qgis/python/plugins/fTools/tools']
>> Hi,
>> I managed to install 2.8 on Red Hat 7. It took me a while to find all dependencies but I made it.
>> Thank you for your support.
>> This is the error.
>> There is a small issue of launching Python Console from QGIS.
>> I got this error:
>> Couldn't load plugin 'processing' from ['/usr/share/qgis/python', '/home/qgisosr/.qgis2/python', '/home/qgisosr/.qgis2/python/plugins', '/usr/share/qgis/python/plugins', '/usr/lib64/python27.zip', '/usr/lib64/python2.7', '/usr/lib64/python2.7/plat-linux2', '/usr/lib64/python2.7/lib-tk', '/usr/lib64/python2.7/lib-old', '/usr/lib64/python2.7/lib-dynload', '/usr/lib64/python2.7/site-packages', '/usr/lib64/python2.7/site-packages/gtk-2.0', '/usr/lib64/python2.7/site-packages/wx-2.8-gtk2-unicode', '/usr/lib/python2.7/site-packages', '/home/qgisosr/.qgis2//python', '/usr/share/qgis/python/plugins/fTools/tools']
>> File "/usr/lib64/python2.7/site-packages/qgis/utils.py", line 196, in loadPlugin
>> __import__(packageName)
>> File "/usr/lib64/python2.7/site-packages/qgis/utils.py", line 478, in _import
>> mod = _builtin_import(name, globals, locals, fromlist, level)
>> File "/usr/share/qgis/python/plugins/processing/__init__.py", line 29, in
>> from processing.tools.general import *
>> File "/usr/share/qgis/python/plugins/processing/tools/general.py", line 28, in
>> from processing.core.Processing import Processing
>> File "/usr/share/qgis/python/plugins/processing/core/Processing.py", line 44, in
>> from processing.gui.Postprocessing import handleAlgorithmResults
>> File "/usr/share/qgis/python/plugins/processing/gui/Postprocessing.py", line 36, in
>> from processing.gui.ResultsDialog import ResultsDialog
>> File "/usr/share/qgis/python/plugins/processing/gui/ResultsDialog.py", line 33, in
>> from processing.ui.ui_DlgResults import Ui_DlgResults
>> File "/usr/share/qgis/python/plugins/processing/ui/ui_DlgResults.py", line 61, in
>> from QtWebKit.QWebView import QWebView
>> ImportError: No module named QtWebKit.QWebView
>> Python version:
>> 2.7.5 (default, Feb 11 2014, 07:46:25)
>> [GCC 4.8.2 20140120 (Red Hat 4.8.2-13)]
>> QGIS version:
>> 2.8.1-Wien Wien, exported
>> Python path: ['/usr/share/qgis/python', u'/home/qgisosr/.qgis2/python', u'/home/qgisosr/.qgis2/python/plugins', '/usr/share/qgis/python/plugins', '/usr/lib64/python27.zip', '/usr/lib64/python2.7', '/usr/lib64/python2.7/plat-linux2', '/usr/lib64/python2.7/lib-tk', '/usr/lib64/python2.7/lib-old', '/usr/lib64/python2.7/lib-dynload', '/usr/lib64/python2.7/site-packages', '/usr/lib64/python2.7/site-packages/gtk-2.0', '/usr/lib64/python2.7/site-packages/wx-2.8-gtk2-unicode', '/usr/lib/python2.7/site-packages', u'/home/qgisosr/.qgis2//python', '/usr/share/qgis/python/plugins/fTools/tools']
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150827/76976376/attachment.html>
