[Qgis-user] Getting There, From Here (How to get this Shapefile into a tablet!)
    Adam Sherman
    adam at sherman.ca
    Sat Aug 29 08:33:25 PDT 2015
Merci Nicolas!
I will give you a call for sure.
A.
On Sat, Aug 29, 2015 at 11:22 AM, Nicolas Cadieux <
nicolas.cadieux at archeotec.ca> wrote:
> Hi Adam,
> You can run QGIS in and Android tablet but it is limited (and last time I
> looked at it, it looked more like a beta project.  It also did not have
> python support). (Correct me someone if I am wrong).  I was also running it
> on a 7 inch tablet and that was also a bad idea.
> Besides, opening a 1.6 GB file on a device that has 1 or 2 GB is probably
> a no go.  You would need to chop it down in smaller pieces. I could help
> you.
> Also, I find that a tablet, in the field, has a very bad battery life
> compared to a true GPS.  Your best bet for search and rescue is probably to
> send that shp file to a track or waypoint file into a good GPS.  QGIS has
> plugins that can do this and a good GPS will have software that will read
> shp file or give you they tools to convert them.  You would need a
> compatibles GPS receiver.
> But it depends on what you need.  If you want, I could help you out with
> the project.  I am in Montreal but from Ottawa and would be happy to help
> out since you will probably go after me in the bush some day. I am in
> Ottawa often.
> You can contact me at home at 514-987-6253.
> Cheers
> Nicolas
> On Aug 29, 2015 10:40 AM, "Adam Sherman [via OSGeo.org]" <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5221770&i=0>> wrote:
> This is maybe slightly off-topic, but I'm hoping this is the right place
> to figure this out: I've been tearing my hair out trying to get from there
> to here, so I'm posting in the hope that someone has done this before me.
> The Province of Quebec, Canada, now publishes road data in multiple
> formats:
> MapInfo (TAB)
> ESRI (SHP)
> ESRI (PGDB)
> ESRI (FGDB)
> Géomédia (MDB)
> I opened the SHP in QGIS and it is incredibly detailed! It contains
> forestry roads not found in any other data that I have looked at. So, I
> want this in my truck. But I have been completely unable to get it to work,
> short of carrying my laptop with me.
> Anyone have any ideas?
> I have:
> A MacBook
> I can run Windows on it
> An Android tablet
> A iPad (iOS)
> Note: The SHP file is 1.6 GB.
> The goal is pretty much any way to get the data onto a tablet with a GPS
> app. I don't mind buying some software, either.
> Thanks for any and all comments or suggestions,
> A.
> Adam Sherman
> Directeur des opérations, Sauvetage bénévole Outaouais
> Director of Operations, Ottawa Volunteer SAR
> CTO, Versature Corp.
> +1 613 797 6819
> Qgis-user mailing list
> <a
> href="/user/SendEmail.jtp?type=node&node=5221761&i=0">[hidden
> email]
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/Getting-There-From-Here-How-to-get-this-Shapefile-into-a-tablet-tp5221761.html
> To start a new topic under Quantum GIS - User, email
> ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, <a href="
> http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg==">click
> here.
> <a href="
> http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id&%2361;instant_html%21nabble%3Aemail.naml&base&%2361;nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs&%2361;notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>"
> style="font:9px serif">NAML
> View this message in context: Re: Getting There, From Here (How to get
> <http://osgeo-org.1560.x6.nabble.com/Getting-There-From-Here-How-to-get-this-Shapefile-into-a-tablet-tp5221761p5221770.html>
> Sent from the Quantum GIS - User mailing list archive
> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html> at
> Nabble.com.
Adam Sherman
+1 613 797 6819
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150829/f9c78a98/attachment.html>
