[Qgis-user] QGIS Web Client: how to expose map sublayers or symbols when generating a graduated/thematic/chloropleth map
Andreas Neumann
a.neumann at carto.net
Mon Aug 31 12:43:47 PDT 2015
Hi Tony,
Unfortunately, QGIS server does not yet expose these categories/rules as
sub layers. The lowest element in the hierarchy is the layer. So there
is no way that QGIS web client could expose these.
I would also like to see this functionality, as I think it is quite
useful for some use cases. But we would have to enhance both QGIS server
and QGIS web client to make this work.
Would you be willing to work on this or help fund this functionality?
Andreas
On 31.08.2015 21:28, Tony Pham wrote:
> Within the QGIS Web Client, how does one enable the sublayers of Map
> Layers to be exposed?
> On my QGIS application, I have created a QGIS project file comprised
> of a chloropleth map (or a graduated map or a thematic map) which
> shows each map object in a different color based on a specific value
> of the map object. In the QGIS application, I am able to check and
> uncheck these "sublayers" that have been created.
> When I view the QGIS project file on the QGIS Web Client, I can view
> the chloropleth map fine as-is. However, I do not have the ability to
> check or uncheck the sublayers of the map layer in question on the
> browser client unlike the QGIS application directly where I may check
> or uncheck each sublayer or symbol color.
> A example is described below. For the following New Zealand map of
> cities generated and displayed using QGIS, each circle has a color
> associated with it based on the population of the city. The larger the
> population, the darker the color of the circle. The QGIS project as
> generated in the QGIS application shows each sublayer's category on
> the left pane. See first link below. When I attempt to post this QGIS
> project on the QGIS Web Client as shown in the second image, I do not
> see each sublayer identified on the Map Layers pane on the left. See
> second link below.
> http://i.stack.imgur.com/qg1gD.png
> http://i.stack.imgur.com/qA54T.png
> image <http://i.stack.imgur.com/qA54T.png>
> View on i.stack.imgur.com <http://i.stack.imgur.com/qA54T.png>
> Preview by Yahoo
> image <http://i.stack.imgur.com/qg1gD.png>
> View on i.stack.imgur.com <http://i.stack.imgur.com/qg1gD.png>
> Preview by Yahoo
> I am interested in viewing these sublayers in my "legend" on the
> browser because the sublayers provide information as to how the
> chloropleth map is broken down by color. Additionally, I would like to
> be able to check and/or uncheck each sublayer (or symbol
> color/category) independently in the QGIS Web Client, similar to how I
> may do so in the QGIS application.
> Within QGIS-Web-Client, are there settings in the javascript files
> that I must modify to enable the exposing of these sublayers of my map
> layers?
> Any help would be appreciated! -tph018nwu
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150831/20040226/attachment.html>
