[Qgis-user] LecoS
    Susan Iremonger
    s.iremonger at gmail.com
    Mon Feb 23 02:51:36 PST 2015
Thank you all very much for your help.
--Susan
On Mon, Feb 23, 2015 at 1:28 AM, Mike Treglia <mtreglia at gmail.com> wrote:
> Thanks for the correction Alex! I guess I haven't checked that in a while.
> Cheers
> Mike
> On Feb 22, 2015, at 6:54 PM, Alex Mandel <tech_dev at wildintellect.com>
> wrote:
> That's outdated info (at one point may have been true). 64bit has it.
> python-scipy, 0.14.0-1
> http://download.osgeo.org/osgeo4w/x86_64/versions.html
> Thanks,
> Alex
> On 02/22/2015 03:53 PM, Mike Treglia wrote:
> Also, pretty sure on windows you need to use 32 bit for SciPy.  It's
> pretty easy to get data into Fragstats from QGIS too as an alternative...
> http://www.umass.edu/landeco/research/fragstats/fragstats.html
> On Feb 22, 2015, at 3:41 PM, Alex Mandel <tech_dev at wildintellect.com>
> wrote:
> I believe OSGeo4W includes Scipy. If you used the QGIS standalone
> installer you probably don't have it.
> http://gis.stackexchange.com/questions/50464/how-to-install-scipy-for-qgis-standalone
> So it doesn't have to be super hard.
> Thanks,
> Alex
> On 02/22/2015 01:31 PM, Susan Iremonger wrote:
> Thanks for that, sadly I think that sounds a bit beyond my capabilities. I
> am using Windows 8.1. I shall look into it further and see if I can get
> some advice on how to do that. Thanks.
> Susan.
> On Sun, Feb 22, 2015 at 9:24 PM, Alex Mandel <tech_dev at wildintellect.com>
> wrote:
> On 02/22/2015 01:19 PM, Susan Iremonger wrote:
> Hi, first time using this mailing list, apologies if I am making errors
> with whom to sent it to. I am asking for info about a plugin called
> LecoS -
> Landscape Ecology Statistics. When I tried to load it (I am using QGIS
> Brighton)  I got a message "The plugin is broken. No module named scipy".
> Does anyone know anything about the plugin and how it can be got working?
> Thanks.
> Susan
> You have to install the Python Scipy library to the same python that
> QGIS uses. Installation of python libraries depends on what operating
> system you are using.
> Thanks,
> Alex
> Qgis-user mailing list
Cara Cottage
Pound road
Carrabaun
Westport
Co. Mayo
Ireland
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150223/81d7816c/attachment.html>
