[Qgis-user] Fwd: pyqgis dxf
Alexandre Busquets
abusquets at gmail.com
Wed Feb 25 04:00:34 PST 2015
the solution:
fitxer="/tmp/prova.dxf|layername=entities|geometrytype=Point"
layer = QgsVectorLayer(fitxer, 'prova', 'ogr')
QgsMapLayerRegistry.instance().addMapLayer(layer)
2015-02-25 11:03 GMT+01:00 Alexandre Busquets <abusquets at gmail.com>:
> Hi Ricard,
> thanks for your help, but this is not a valid option for me. I need load
> the layer directly, without the "Select vector layers to add" dialog.
> 2015-02-25 10:55 GMT+01:00 Richard Duivenvoorde <rdmailings at duif.net>:
>> On 25-02-15 08:05, Alexandre Busquets wrote:
>> > Hi,
>> > can somebody help me with load a dxf file as a vector layer?
>> > Is QgsDataSourceURI an option? I tried with this code, but I haven't
>> > been lucky.
>> > fitxer="/tmp/prova.dxf"
>> > uri = QgsDataSourceURI()
>> > uri.setDatabase(fitxer)
>> > uri.setDataSource('', 'entities', 'OGR_GEOMETRY',
>> > "OGR_GEOMETRY='POINT'", 'fid')
>> iface.addVectorLayer('/tmp/points.dxf', 'mydxflayer', 'ogr')
>> works for me in the python console
>> did not try the QGSDataSourceURI-path, but that should also work
>> (note that depending on you settings and data you will get one or more
>> dialogs (for crs and/or sub layers)
>> Regards,
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150225/0376fdd1/attachment.html>
