[Qgis-user] Help! Cirle radius
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Sat Jan 3 18:32:46 PST 2015
There are a number of plugin that can make circles. ArcheoCad, is one of them. If is does not work the way you want, look for an other under CAD like plugins. You can also create a 50k buffer around points.
Once you have the circle, save the layer and right click on the circle, and you will get the area. If you want, you can create a field called 'area' in the layer with circles and you can generate the area using the Qgis field calculator using and expression.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112 Fax: 514.381.4995
Le 2015-01-03 17:50, "Paula Urbina [via OSGeo.org]" <ml-node+s1560n5179899h30 at n6.nabble.com> a écrit :
Could you please tell me, How I can assign a circle radius (X=50 km) to a location? And then How I can calculated the area covered by some circles? Please, help me!!!!
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/Help-Cirle-radius-tp5179899.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Help-Cirle-radius-tp5179899p5179913.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150103/624ca205/attachment.html>
