[Qgis-user] Coordinate Display
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Fri Jan 9 13:43:32 PST 2015
Go to the projects properties\CRS and filter using "csrs".  You will find all the projections used in Canada.  Projection with " Atlas " is the name usually gives us a look we are familiar with.  Make sure you have CRS on the fly activated.
I have a google group called QGIS Canada for this type of question relating to Canada.  You are welcome to join.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112  Fax: 514.381.4995
Le 2015-01-09 16:03, "swaxolez [via OSGeo.org]" <ml-node+s1560n5180869h0 at n6.nabble.com> a écrit :
	If I load a map with a single layer with a projection such as BC Albers and then want to display latitude and longitude coordinates while panning and moving around how do I do this?
I tried changing the map units in Project Properties but the resulting latitude and longitude is grossly incorrect.  I can turn on CRS and then reproject into something like EPSG:4326 and then my latitude and longitude work properly but then my map data is skewed due to the reprojection and not displaying the way I'd like to see it.
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/Coordinate-Display-tp5180869.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Coordinate-Display-tp5180869p5180876.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150109/af34e988/attachment.html>
