[Qgis-user] Coordinate Display
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Fri Jan 9 15:45:26 PST 2015
If you choose a projection that is in long lat, you will have longitude and latitude. If you try, for example, EPSG 4617, for your project, you will have long\lat as it is a "geographic coordinate system". If you choose EPSG 3157, you will get meters as it is a " projected coordinate system ".
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112 Fax: 514.381.4995
Le 2015-01-09 18:07, "swaxolez [via OSGeo.org]" <ml-node+s1560n5180888h89 at n6.nabble.com> a écrit :
Hi Nicolas, Thanks for the response but I think I’m not explaining myself clearly. I have a map that I want to keep in the BC Albers (meters) projection but I also want to have the coordinate display show in decimal degrees. It seems with QGIS I currently cannot have it both ways. In Arcmap or Manifold, I am able to keep the map projection and display mouse coordinates as latitude and longitude or decimal degrees regardless of projection.
Willem Buitendyk
On Jan 9, 2015, at 1:43 PM, Nicolas Cadieux < [hidden email] > wrote: Hi, Go to the projects properties\CRS and filter using "csrs". You will find all the projections used in Canada. Projection with " Atlas " is the name usually gives us a look we are familiar with. Make sure you have CRS on the fly activated. I have a google group called QGIS Canada for this type of question relating to Canada. You are welcome to join. Nicolas Cadieux M.Sc.
Le 2015-01-09 16:03, "swaxolez [via OSGeo.org ]" <<a href="x-msg://8/user/SendEmail.jtp?type=node&node=5180876&i=0" target="_top" rel="nofollow" link="external" class="">[hidden email] > a écrit : <blockquote style='border-left:2px solid #CCCCCC;padding:0 1em' style="border-left:2px solid #CCCCCC;padding:0 1em" class="quote">
If I load a map with a single layer with a projection such as BC Albers and then want to display latitude and longitude coordinates while panning and moving around how do I do this?
I tried changing the map units in Project Properties but the resulting latitude and longitude is grossly incorrect. I can turn on CRS and then reproject into something like EPSG:4326 and then my latitude and longitude work properly but then my map data is skewed due to the reprojection and not displaying the way I'd like to see it.
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/Coordinate-Display-tp5180869.html
To start a new topic under Quantum GIS - User, email <a href="x-msg://8/user/SendEmail.jtp?type=node&node=5180876&i=1" target="_top" rel="nofollow" link="external" class="">[hidden email]
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: Re: Coordinate Display
Sent from the Quantum GIS - User mailing list archive at Nabble.com . _______________________________________________ Qgis-user mailing list [hidden email] http://lists.osgeo.org/mailman/listinfo/qgis-user _______________________________________________
[hidden email]
http://osgeo-org.1560.x6.nabble.com/Coordinate-Display-tp5180869p5180888.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Coordinate-Display-tp5180869p5180892.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150109/0dcadcc9/attachment.html>
