[Qgis-user] Changing raster data to model a landdfill?
    Nicolas Cadieux
    nicolas.cadieux at archeotec.ca
    Mon Jan 12 09:56:04 PST 2015
Hi, there are many ways to do it. This is what I would do.
First you need to model the landfill.  You will need point data or contour lines with the z info on the land fill.
Second, you need to interpolate the vector data to create a raster model of the land fill.  The polyline can be used as a break line. (Raster, interpolation or use gdal-dem in Raster\analysis\dem or Grass). Find the best interpolation for your data and needs. For more predictable results, use the same griding scheme as your original data.
Finally, use the raster calculator and do
Original layer - landfill model = new layer (carefully select the extent, columns and rows of the new layer).  Raster math is done on pixel centroids.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112  Fax: 514.381.4995
Le 2015-01-03 18:06, "berounba [via OSGeo.org]" <ml-node+s1560n5179900h61 at n6.nabble.com> a écrit :
	Could you please tell me, how I can model a virtual landfill by changing existing raster data inside a polyline shape. I have two areas. Area 1 with fixed z-value Area 2, which is representing a slope Please help beroubt _______________________________________________
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/Changing-raster-data-to-model-a-landdfill-tp5179900.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Changing-raster-data-to-model-a-landdfill-tp5179900p5181128.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150112/42261d40/attachment.html>
