[Qgis-user] Re : Edit print composer
Andreas Neumann
a.neumann at carto.net
Tue Jan 13 15:06:34 PST 2015
It isn't directly possible.
However, starting with QGIS 2.6 you can use the visibility presets
(bookmarks of combinations of layer visiblities) which can be used
directly in both the main window and the print composer. So you can
switch very quickly in both windows.
Andreas
On 13.01.2015 23:57, drruddy gmail wrote:
> Hello Matt,
> I don’t think that’s possible. Would be interested to know if it can
> be done but I’ve only been able to change layers in composer from map
> MR
> On 13 January 2015 at 22:48:42, Matt Boyd (mattslists at gmail.com
> <mailto:mattslists at gmail.com>) wrote:
>> Thanks junior,
>> This is what I'm doing at the moment. What I'd like is to be able to
>> load the locked items in the print composer to the main window.
>> Sorry if I wasn't clear.
>> On 13/01/2015 7:02 pm, "Junior" <delazj at gmail.com
>> <mailto:delazj at gmail.com>> wrote:
>> Hi Matt,
>> Once you have activated all the layers that should be displayed
>> in your print composer, select the map item inside your print
>> composer and check the option "lock layers for map item" in the
>> properties tab.
>> More info can be found below "Composer Items" chapter in this
>> link
>> http://docs.qgis.org/2.6/en/docs/user_manual/print_composer/print_composer.html
>> Envoyé depuis mon HTC
>> ----- Reply message -----
>> De : "Matt Boyd" <mattslists at gmail.com <mailto:mattslists at gmail.com>>
>> Pour : "qgis-user" <qgis-user at lists.osgeo.org
>> <mailto:qgis-user at lists.osgeo.org>>
>> Objet : [Qgis-user] Edit print composer
>> Date : mar., janv. 13, 2015 06:02
>> Hi QGISers,
>> I've got a few different print composers in the same project and
>> it's slightly painful to go back and turn layers on/off when I
>> want to edit one of them.
>> Is there an easy way to turn on/off the layers in a particular
>> print composer automagically?
>> THanks
>> Matt
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150114/8d67d64c/attachment.html>
