[Qgis-user] Re : Edit print composer
    Matt Boyd
    mattslists at gmail.com
    Tue Jan 13 18:48:36 PST 2015
thanks Andreas,
every time I turn around there's something new in QGIS (which is great).
just browsing through the manual, are you able to give me some tips on how
to enable / use this functionality.
On Wed, Jan 14, 2015 at 10:06 AM, Andreas Neumann <a.neumann at carto.net>
wrote:
>  Hi,
> It isn't directly possible.
> However, starting with QGIS 2.6 you can use the visibility presets
> (bookmarks of combinations of layer visiblities) which can be used directly
> in both the main window and the print composer. So you can switch very
> quickly in both windows.
> Andreas
> On 13.01.2015 23:57, drruddy gmail wrote:
>  Hello Matt,
>  I don’t think that’s possible. Would be interested to know if it can be
> done but I’ve only been able to change layers in composer from map
>  MR
> On 13 January 2015 at 22:48:42, Matt Boyd (mattslists at gmail.com) wrote:
>  Thanks junior,
> This is what I'm doing at the moment. What I'd like is to be able to load
> the locked items in the print composer to the main window.
> Sorry if I wasn't clear.
> On 13/01/2015 7:02 pm, "Junior" <delazj at gmail.com> wrote:
>>  Hi Matt,
>> Once you have activated all the layers that should be displayed in your
>> print composer, select the map item inside your print composer and check
>> the option "lock layers for map item" in the properties tab.
>> More info can be found below "Composer Items" chapter in this link
>> http://docs.qgis.org/2.6/en/docs/user_manual/print_composer/print_composer.html
>>  Envoyé depuis mon HTC
>> ----- Reply message -----
>> De : "Matt Boyd" <mattslists at gmail.com>
>> Pour : "qgis-user" <qgis-user at lists.osgeo.org>
>> Objet : [Qgis-user] Edit print composer
>> Date : mar., janv. 13, 2015 06:02
>> Hi QGISers,
>> I've got a few different print composers in the same project and it's
>> slightly painful to go back and turn layers on/off when I want to edit one
>> of them.
>>  Is there an easy way to turn on/off the layers in a particular print
>> composer automagically?
>>  THanks
>> Matt
>  _______________________________________________
> Qgis-user mailing list
> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150114/f1f08c45/attachment.html>
