[Qgis-user] point sampling tool QGIS 2.6
    Nicolas Cadieux
    nicolas.cadieux at archeotec.ca
    Thu Jan 15 06:21:58 PST 2015
The point sampling plugin works with QGIS 2.6.  You need to install it and then turn it on in the plugin menu.  I have been using it myself in 2.6.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112  Fax: 514.381.4995
Le 2015-01-15 05:56, "Torsten Lange-2 [via OSGeo.org]	" <ml-node+s1560n5181635h46 at n6.nabble.com> a écrit :
	Hi, I wonder, where I could find a working "point sampling tool" for QGis 2.6. The respective python plugin only works with QGis < 2.x. Also didn't find one in the menu. The only processing tool seem to have the needed func is Saga "Add grid values to points". However, can't manage to get a point shape or csv from that tool. Any one knows, what I have to give as output file? New file doesn't work, as message says it couldn't find the file to open. If I use the input point shape as output shape the module runs, but it doesn't add the grid values. If I leave the output to temporary, the message says again that it couln't open or create the file. Am I doing something wrong? However, if there is a newer point sampling plugin available for QGis, could you please point me to. Our IT department obviously blocks the online plugin search from within QGis. Thank you, Torsten
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/point-sampling-tool-QGIS-2-6-tp5181635.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/point-sampling-tool-QGIS-2-6-tp5181635p5181685.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150115/8841412a/attachment.html>
