[Qgis-user] point sampling tool QGIS 2.6
Torsten Lange torsten.lange at mail.de
Fri Jan 23 03:28:13 PST 2015
Thanks Nicolas,
I took the wrong zip (version 0.38) from http://plugins.qgis.org/plugins/plugins.xml as the ?qgis=2.6 was missing in the URL. That's why I assumed its unmaintained.
Cheers, Torsten
Am 22-Jan-2015 15:07:39 +0100 schrieb nicolas.cadieux at archeotec.ca:
Works fine in my new install. Installed it and ran an example.
But version 0.3.7 is for Qgis 1.0 plus. Current version in 0.4 and is for Qgis 2.0.0 plus. That could be the problem. I don't see that it's no longer maintained...
Nicolas Cadieux M.Sc.
 Les Entreprises Archotec inc.
 8548, rue Saint-Denis Montral H2P 2H2
 Tlphone: 514.381.5112 Fax: 514.381.4995 Le 2015-01-22 08:40, Torsten Lange  a crit :
Hi, hi Nicolas,
took a bit longer to come back to the issue. I have QGis 2.6 under Windows. It straightly refuses to accept the point-sampling-tool. Version is 0.38, which seams to be the last version available befor the project became unmaintained. Nicolas, do you run it under Linux?
Cheers, Torsten
 Am 15-Jan-2015 15:23:03 +0100 schrieb nicolas.cadieux at archeotec.ca:
 The point sampling plugin works with QGIS 2.6. You need to install it and then turn it on in the plugin menu. I have been using it myself in 2.6.
 Tlphone: 514.381.5112 Fax: 514.381.4995 Le 2015-01-15 05:56, "Torsten Lange-2 [via OSGeo.org] "  a crit :
I wonder, where I could find a working "point sampling tool" for QGis 2.6. The respective python plugin only works with QGis < 2.x. Also didn't find one in the menu.
The only processing tool seem to have the needed func is Saga "Add grid values to points". However, can't manage to get a point shape or csv from that tool. Any one knows, what I have to give as output file? New file doesn't work, as message says it couldn't find the file to open. If I use the input point shape as output shape the module runs, but it doesn't add the grid values. If I leave the output to temporary, the message says again that it couln't open or create the file. Am I doing something wrong?
However, if there is a newer point sampling plugin available for QGis, could you please point me to. Our IT department obviously blocks the online plugin search from within QGis.
Thank you, Torsten
Qgis-user mailing list
 If you reply to this email, your message will be added to the discussion below: http://osgeo-org.1560.x6.nabble.com/point-sampling-tool-QGIS-2-6-tp5181635.html To start a new topic under Quantum GIS - User, email NAML
View this message in context: Re: point sampling tool QGIS 2.6
 Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150123/1cfd9716/attachment.html>
