[Qgis-user] Creating oblique views of QGIS layers
    Zoltan Szecsei
    zoltans at geograph.co.za
    Sun Jan 18 22:17:52 PST 2015
Cool - I'll take a look at GMT.
Thanks Brent.
Regards,
Zoltan
On 2015/01/18 19:33, Brent Wood wrote:
> Hi,
> I have not done this in QGIS, but have done it often with GMT. I've
> also used it to generate a page of maps showing a time series of
> survey results, each as a 3D perspective plot.
> A script draws a layer, then the next, applying a Z offset to each
> layer as it renders them, building the stack. You can use pstext to
> add text for each layer (which can be on the page - does not have to
> be in the map extent. At the end ps2raster can convert the postscript
> to bitmap which you cam add to your layout in the QGIS composer.
> Depending on how complex your layers are, the script can get a bit
> complicated... the nature of the beast. QGIS
> (or GDAL) can save your QGIS vector layers in GMT format, rasters can
> also be converted to a format GMT can render.
> Brent Wood
> *From:* Zoltan Szecsei <zoltans at geograph.co.za>
> *To:* "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
> *Sent:* Monday, January 19, 2015 2:47 AM
> *Subject:* [Qgis-user] Creating oblique views of QGIS layers
> Hi,
> I need to create a "layer stack" view of some QGIS vector data.
> Is there a way to do this in QGIS?
> (Rather like what you get when you Google "Images of GIS layer")
> I want it for a printed map view, and be in place of a traditional 'Key'
> in the one corner of the map plot.
> Regards & TIA,
> Zoltan
> Zoltan Szecsei PrGISc [PGP0031]
> Geograph (Pty) Ltd.
> GIS and Photogrammetric Services
> P.O. Box 7, Muizenberg 7950, South Africa.
> Mobile: +27-83-6004028
> Fax:    +27-86-6115323    www.geograph.co.za
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
Geograph (Pty) Ltd.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150119/94b62e3c/attachment.html>
