[Qgis-user] DEM tools not working (slope, hillshade
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Wed Jan 21 19:08:52 PST 2015
What platform are you using? (Windows, mac, linux?) What algorithm are you using? We need to know because there are a number of way to do that in QGIS.
If you are on windows and the problem is across two versions of Qgis, I would delete the registry keys and do a fresh install deleting all plugins directories and try again.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112  Fax: 514.381.4995
Le 2015-01-21 21:59, "Kavinda [via OSGeo.org]" <ml-node+s1560n5183008h9 at n6.nabble.com> a écrit :
	Hi all,
I am continously failing to use any morphological analysis tool in QGIS. When I am trying to give an output file name the program stuck and need to force shoutdown. tried with 2.6 and 2.4 versions. Use SRTM data and reprojected to UTM coordinte system. Please help this matter if you know the reason already.
Thanks
Kavinda
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/DEM-tools-not-working-slope-hillshade-tp5183008.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/DEM-tools-not-working-slope-hillshade-tp5183008p5183009.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150121/2461215f/attachment.html>
