[Qgis-user] DEM tools not working (slope, hillshade
Kavinda
kavindagunasekara at gmail.com
Wed Jan 21 19:15:33 PST 2015
Hi Nicolas,
I`m on windows, I tried slope,hillshade, all failed. When I used processing
toolbox GDAL/OGR tools -> analysis -> slope only that work for temporary
output file.
As you said both versions in my PC and it may cause the problem. If it easy
to mail plase let me know how to delete the registry keys.
Thanks
Kavinda
On Thu, Jan 22, 2015 at 12:08 PM, Nicolas Cadieux [via OSGeo.org] <
ml-node+s1560n5183009h40 at n6.nabble.com> wrote:
> Hi,
> What platform are you using? (Windows, mac, linux?) What algorithm are you
> using? We need to know because there are a number of way to do that in
> QGIS.
> If you are on windows and the problem is across two versions of Qgis, I
> would delete the registry keys and do a fresh install deleting all plugins
> directories and try again.
> Nicolas Cadieux M.Sc.
> Les Entreprises Archéotec inc.
> 8548, rue Saint-Denis Montréal H2P 2H2
> Téléphone: 514.381.5112 Fax: 514.381.4995
> Le 2015-01-21 21:59, "Kavinda [via OSGeo.org]" <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5183009&i=0>> a écrit :
> Hi all,
> I am continously failing to use any morphological analysis tool in QGIS. *When
> I am trying to give an output file name the program stuck and need to force
> shoutdown.*
> tried with 2.6 and 2.4 versions. Use SRTM data and reprojected to UTM
> coordinte system. Please help this matter if you know the reason already.
> Thanks
> Kavinda
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/DEM-tools-not-working-slope-hillshade-tp5183008.html
> To start a new topic under Quantum GIS - User, email [hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5183009&i=1>
> To unsubscribe from Quantum GIS - User, click here.
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> below:
> http://osgeo-org.1560.x6.nabble.com/DEM-tools-not-working-slope-hillshade-tp5183008p5183009.html
> To unsubscribe from DEM tools not working (slope, hillshade, click here
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5183008&code=a2F2aW5kYWd1bmFzZWthcmFAZ21haWwuY29tfDUxODMwMDh8ODUwMTE5MjE3>
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/DEM-tools-not-working-slope-hillshade-tp5183008p5183010.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150121/e705a227/attachment.html>
