[Qgis-user] How to get rid of table name while joining table
Andreas Neumann a.neumann at carto.net
Fri Jan 23 01:43:42 PST 2015
Excellent - thanks for this modification!
I noticed that there is a regression. The GUI to choose certain columns
from the joined table is always deactivated. So no chance anymore to
select certain fields.
I don't know when this regression was introduced.
Tested with PostgreSQL tables.
I opened a bug report: http://hub.qgis.org/issues/12042
Andreas
On 22.01.2015 16:39, Matthias Kuhn wrote:
> I just merged this functionality.
> When you create a join, you may specify a prefix. This can be an empty
> string.
> By default it is unspecified and "layername_" is used, so it is exactly
> like before.
> Best,
> Matthias
> On 20.01.2015 11:25, Nathan Woodrow wrote:
>> I think leaving it up to the user is the best option here.
>> Nathan
>> On Tue, 20 Jan 2015 8:17 pm Andreas Neumann <a.neumann at carto.net> wrote:
>>>   Then you can't distinguish a joined column from a normal column. And it
>>> would open up naming conflicts - which is the reason why the layer name
>>> prefix was introduced. Bad, in my opinion.
>>> Andreas
>>> On 20.01.2015 11:01, Harish wrote:
>>>   Thanks for kind replies. A feature request for adding an option to
>>> not prepend layer names will be better.
>>>   Regards
>>> On Tue, Jan 20, 2015 at 3:18 PM, Andreas Neumann <a.neumann at carto.net>
>>> wrote:
>>>> or - the even better way would be to allow the user to define a very
>>>> short user-defined table name prefix (1-3 chars).
>>>> Andreas
>>>> On 20.01.2015 10:45, Anita Graser wrote:
>>>>>   On Tue, Jan 20, 2015 at 9:41 AM, Harish <harry.om2000 at gmail.com> wrote:
>>>>>> I do not want name of table to be included in attribute names when
>>>>>> joining
>>>>>> tabular data to vector layers which are further truncated when saving
>>>>>> the
>>>>>> layer permanently.
>>>>> Hi Harish,
>>>>> Layer names are prepended to avoid troube with columns having the same
>>>>> name (often the case with "id" or "name" columns).
>>>>> You can change the layer name to empty, then only an underscore _ will
>>>>> be prepended - this saves characters.
>>>>> An alternative is to open a feature request for adding an option to
>>>>> not prepend layer names.
>>>>> Best wishes,
>>>>> Anita
>>>>>   _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
