[Qgis-user] How to get rid of table name while joining table
Matthias Kuhn matthias.kuhn at gmx.ch
Fri Jan 23 01:52:19 PST 2015
That was probably me at the same time...
Looking into it right now,
thank you for reporting
On 23.01.2015 10:43, Andreas Neumann wrote:
> Excellent - thanks for this modification!
> I noticed that there is a regression. The GUI to choose certain
> columns from the joined table is always deactivated. So no chance
> anymore to select certain fields.
> I don't know when this regression was introduced.
> Tested with PostgreSQL tables.
> I opened a bug report: http://hub.qgis.org/issues/12042
> Andreas
> On 22.01.2015 16:39, Matthias Kuhn wrote:
>> I just merged this functionality.
>> When you create a join, you may specify a prefix. This can be an empty
>> string.
>> By default it is unspecified and "layername_" is used, so it is exactly
>> like before.
>> Best,
>> Matthias
>> On 20.01.2015 11:25, Nathan Woodrow wrote:
>>> I think leaving it up to the user is the best option here.
>>> Nathan
>>> On Tue, 20 Jan 2015 8:17 pm Andreas Neumann <a.neumann at carto.net>
>>> wrote:
>>>>   Then you can't distinguish a joined column from a normal column.
>>>> And it
>>>> would open up naming conflicts - which is the reason why the layer
>>>> name
>>>> prefix was introduced. Bad, in my opinion.
>>>> Andreas
>>>> On 20.01.2015 11:01, Harish wrote:
>>>>   Thanks for kind replies. A feature request for adding an option to
>>>> not prepend layer names will be better.
>>>>   Regards
>>>> On Tue, Jan 20, 2015 at 3:18 PM, Andreas Neumann <a.neumann at carto.net>
>>>> wrote:
>>>>> or - the even better way would be to allow the user to define a very
>>>>> short user-defined table name prefix (1-3 chars).
>>>>> Andreas
>>>>> On 20.01.2015 10:45, Anita Graser wrote:
>>>>>>   On Tue, Jan 20, 2015 at 9:41 AM, Harish
>>>>>> <harry.om2000 at gmail.com> wrote:
>>>>>>> I do not want name of table to be included in attribute names when
>>>>>>> joining
>>>>>>> tabular data to vector layers which are further truncated when
>>>>>>> saving
>>>>>>> the
>>>>>>> layer permanently.
>>>>>> Hi Harish,
>>>>>> Layer names are prepended to avoid troube with columns having the
>>>>>> same
>>>>>> name (often the case with "id" or "name" columns).
>>>>>> You can change the layer name to empty, then only an underscore _
>>>>>> will
>>>>>> be prepended - this saves characters.
>>>>>> An alternative is to open a feature request for adding an option to
>>>>>> not prepend layer names.
>>>>>> Best wishes,
>>>>>> Anita
>>>>>>   _______________________________________________
>>>>>> Qgis-user mailing list
>>>>>> Qgis-user at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
