[Qgis-user] R: Re: Aerograms style
labiancamarilena at libero.it
Fri Jan 23 03:36:19 PST 2015
I meant that I have seen in several atlases that on map instead of changes in
color were pie charts with variable dimensions showing the intensity of a
phenomenon.
I do not know if I explained well.
This is an example:
http://www.cartografia.regione.lombardia.
it/oopp/html/help/images/mappaHideShowLabel.png
Thanks a lot
Marilena
ssaggio originale----
>Da: tech_dev at wildintellect.com
>Data: 22/01/2015 21.24
>A: "Andre Joost"<andre+joost at nurfuerspam.de>, <qgis-user at lists.osgeo.org>
>Ogg: Re: [Qgis-user] Aerograms style
>On 01/22/2015 12:02 PM, Andre Joost wrote:
>> Am 21.01.2015 um 20:16 schrieb
>> labiancamarilena at libero.it:
>>> Dear all, I would like to customize the map using the style as
>>> aerograms to show the intensity of a phenomenon, but I do not find
>>> this option in QGIS. Can anyone help me?
>> I am not sure what you mean by aerogram style.
>> You can use a categorized or graduated style with colour ramps of reds,
>> greens or blues on the data field you want to visualize, and add some
>> transparency if you want to have a basemap shining through.
>> HTH,
>> André Joost
>Did you mean something like this:
>http://www.nasa.gov/images/content/583575main_Fig.%203.jpg
>With the arrows showing direction and magnitude?
>Thanks,
>Alex
>_______________________________________________
>Qgis-user mailing list
>Qgis-user at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/qgis-user
