[Qgis-user] Fwd: QGIS crash on loading projects
Luigi Pirelli luipir at gmail.com
Tue Jan 27 02:08:18 PST 2015
Hi
on Win, the qgis-dev version is compiled in debug mode to produce logging.
most of the generated log can controlled using some env vars... more info here:
http://qgis.org/api/classQgsLogger.html#details
there can be more QgsLogger messages available not filtered by
compilation directives or because used in plugins => try to set env
vars also on 2.6.1
read the generated log with some editor more clever then notepad...
like notepad++ or similar.
regards, Luigi Pirelli
On 26 January 2015 at 23:29, Matt Boyd <mattslists at gmail.com> wrote:
> Just a bump to this question, does anyone know how to enable logging or find
> the log file? I really don't want to have to re create all my project files
> and I can't get any of the my old projects to open.
> On Fri, Jan 23, 2015 at 3:09 PM, Matt Boyd <mattslists at gmail.com> wrote:
>> On Fri, Jan 23, 2015 at 2:58 PM, Nicolas Cadieux
>> <nicolas.cadieux at archeotec.ca> wrote:
>>> Hi,
>>> If you had and "openlayer" opened (like google earth or bing map), but
>>> but did not reinstall the plugin, it can crash.  Try installing that plugin
>>> and see what happens...
>> Nope, that doesn't help.
>>> Nicolas Cadieux M.Sc.
>>> Les Entreprises Archéotec inc.
>>> 8548, rue Saint-Denis Montréal H2P 2H2
>>> Téléphone: 514.381.5112  Fax: 514.381.4995
>>> Le 2015-01-22 22:46, "Matt Boyd [via OSGeo.org]" <[hidden email]> a écrit
>>> woops, forgot,
>>> windows 7 64 bit,
>>> qgis 2.6 installed via osgeo4w64
>>> On Fri, Jan 23, 2015 at 2:45 PM, Matt Boyd <[hidden email]> wrote:
>>> Hi QGISers,
>>> for some reason today I can't load saved QGIS projects. QGIS crashes at
>>> abour 95% loaded with no information in the notification about why.
>>> I've tried reinstall from osgeo4w64, reboot, start from command line,
>>> disabling all plugins.
>>> Where's the log file kept and is there a way to enable logging from the
>>> osgeo cl window in windows 7?
>>> About the only thing that's different today is a few updates, one of them
>>> being a .NET windows update.
>>> Thanks
>>> Matt
>>> Qgis-user mailing list
>>> [hidden email]
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> If you reply to this email, your message will be added to the discussion
>>> below:
>>> http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183269.html
>>> To start a new topic under Quantum GIS - User, email [hidden email]
>>> To unsubscribe from Quantum GIS - User, click here.
>>> NAML
>>> View this message in context: Re: QGIS crash on loading projects
>>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>>> Qgis-user at lists.osgeo.org
