[Qgis-user] Fwd: QGIS crash on loading projects
Matt Boyd
mattslists at gmail.com
Mon Jan 26 21:05:27 PST 2015
On Tue, Jan 27, 2015 at 11:17 AM, Nicolas Cadieux <
nicolas.cadieux at archeotec.ca> wrote:
> Hi,
> Personally this is what I would do.
> Completely purges Qgis from your system. (Delete plugin directories, AND
> the Qgis registry keys.) Reboot.
> I would install Qgis 2.6.1 using the OSGEO install.
I followed these steps. My install was already done via osge064w and
uninstalling was a little tricky.
I removed the directories and the registry entries.
I then reinstalled QGIS via the express installer.
QGIS wouldn't start giving an error about jvm.dll missing from my computer.
I manually selected the java install via the advanced option, jvm is
installed and in a subfolder in C:\osgeo4w64
I suspect it's a path problem, working on this.
I would make sure that all mapped drive are properly remapped with the
> proper passwords, I would install the open layer plugin and wms or other
> data servers. Make sure the symbols are reinstalled if you had new ones and
> also make sure the .svg symbol images are well mapped.
> If the problem persists, I would repurge Qgis, install and older version
> and try again.
> Finally, i would then start looking at the project files with a text
> editor to try to understand the problem. I is likely the crash is cause by
> a layer that cannot be opened and that this layer depends on a plugin like
> openlayer, a mapped drive, wms servers... That would be my guess.
> Nicolas Cadieux M.Sc.
> Les Entreprises Archéotec inc.
> 8548, rue Saint-Denis Montréal H2P 2H2
> Téléphone: 514.381.5112 Fax: 514.381.4995
> Le 2015-01-26 18:16, "Matt Boyd [via OSGeo.org]" <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5183862&i=0>> a écrit :
> Thanks Lene,
> I tried that on a 3 projects this morning with no change to the behaviour.
> I've had 2.6.1 for a while now and these projects opened in that early last
> week.
> I've also tried loading older projects that are still in 2.0, 2.2, and 2.4
> format and the same thing happens.
> Most of my projects are on a network drive and I've managed to get a step
> further by copying those project files to a local drive. I then get the
> "handle bad layers" dialog, then qgis crashes. I need to dig a little to
> see if this is a problem in case someone has moved some of the layers the
> dialog is referring to but this hasn't caused a crash before.
> Is this behaviour logged anywhere?
> Thanks
> Mat
> On Tue, Jan 27, 2015 at 9:58 AM, Lene Fischer <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5183855&i=0>> wrote:
> Please first update to 2.6.1.
> If you have your crashed projects – you also have projects named with a
> .qgs~. Rename this project and delete the ~ and open it as usual.
> A lot of my students had the same problem last week – but only the ones
> who had forgotten to update to 2.6.1
> Hope this can help you.
> Regards
> *Lene Fischer*
> Associate Professor
> *Department of Geosciences and Natural Resource Management*
> University of Copenhagen
> MOB <a href="tel:%2B45%2040115084" value="+4540115084" target="_blank">+45
> 40115084
> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5183855&i=1>
> [image: cid:image001.gif at 01D03029.2F3EC6A0]
> *Fra:* [hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5183855&i=2> [mailto:[hidden
> email] <http:///user/SendEmail.jtp?type=node&node=5183855&i=3>] *På vegne
> af *Matt Boyd
> *Sendt:* 26. januar 2015 23:29
> *Til:* qgis-user
> *Emne:* [Qgis-user] Fwd: QGIS crash on loading projects
> Just a bump to this question, does anyone know how to enable logging or
> find the log file? I really don't want to have to re create all my project
> files and I can't get any of the my old projects to open.
> On Fri, Jan 23, 2015 at 3:09 PM, Matt Boyd <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5183855&i=4>> wrote:
> On Fri, Jan 23, 2015 at 2:58 PM, Nicolas Cadieux <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5183855&i=5>> wrote:
> Hi,
> If you had and "openlayer" opened (like google earth or bing map), but but
> did not reinstall the plugin, it can crash. Try installing that plugin and
> see what happens...
> Nope, that doesn't help.
> Téléphone: <a href="tel:514.381.5112" target="_blank">514.381.5112 Fax:
> <a href="tel:514.381.4995" target="_blank"> 514.381.4995
> Le 2015-01-22 22:46, "Matt Boyd [via OSGeo.org]" <[hidden email]
> <http://user/SendEmail.jtp?type=node&node=5183270&i=0>> a écrit :
> woops, forgot,
> windows 7 64 bit,
> qgis 2.6 installed via osgeo4w64
> On Fri, Jan 23, 2015 at 2:45 PM, Matt Boyd <[hidden email]
> <http://user/SendEmail.jtp?type=node&node=5183269&i=0>> wrote:
> Hi QGISers,
> for some reason today I can't load saved QGIS projects. QGIS crashes at
> abour 95% loaded with no information in the notification about why.
> I've tried reinstall from osgeo4w64, reboot, start from command line,
> disabling all plugins.
> Where's the log file kept and is there a way to enable logging from the
> osgeo cl window in windows 7?
> About the only thing that's different today is a few updates, one of them
> being a .NET windows update.
> Thanks
> Matt
> Qgis-user mailing list
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5183269&i=1>
> *If you reply to this email, your message will be added to the discussion
> below:*
> http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183269.html
> To start a new topic under Quantum GIS - User, email [hidden email]
> <http://user/SendEmail.jtp?type=node&node=5183270&i=1>
> To unsubscribe from Quantum GIS - User, click here.
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> View this message in context: Re: QGIS crash on loading projects
> <http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183270.html>
> Sent from the Quantum GIS - User mailing list archive
> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html> at
> Nabble.com.
> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5183855&i=6>
> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5183855&i=7>
> below:
> http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183855.html
> <http:///user/SendEmail.jtp?type=node&node=5183862&i=1>
> NAML
> View this message in context: Re: Fwd: QGIS crash on loading projects
> <http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183862.html>
> Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150127/85c3cdfb/attachment.html>
