[Qgis-user] Fwd: QGIS crash on loading projects
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Mon Jan 26 16:17:58 PST 2015
Personally this is what I would do.
Completely purges Qgis from your system. (Delete plugin directories, AND the Qgis registry keys.) Reboot.
I would install Qgis 2.6.1 using the OSGEO install.
I would make sure that all mapped drive are properly remapped with the proper passwords, I would install the open layer plugin and wms or other data servers. Make sure the symbols are reinstalled if you had new ones and also make sure the .svg symbol images are well mapped.
If the problem persists, I would repurge Qgis, install and older version and try again.
Finally, i would then start looking at the project files with a text editor to try to understand the problem. I is likely the crash is cause by a layer that cannot be opened and that this layer depends on a plugin like openlayer, a mapped drive, wms servers... That would be my guess.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112 Fax: 514.381.4995
Le 2015-01-26 18:16, "Matt Boyd [via OSGeo.org]" <ml-node+s1560n5183855h66 at n6.nabble.com> a écrit :
Thanks Lene, I tried that on a 3 projects this morning with no change to the behaviour. I've had 2.6.1 for a while now and these projects opened in that early last week. I've also tried loading older projects that are still in 2.0, 2.2, and 2.4 format and the same thing happens. Most of my projects are on a network drive and I've managed to get a step further by copying those project files to a local drive. I then get the "handle bad layers" dialog, then qgis crashes. I need to dig a little to see if this is a problem in case someone has moved some of the layers the dialog is referring to but this hasn't caused a crash before. Is this behaviour logged anywhere? Thanks Mat On Tue, Jan 27, 2015 at 9:58 AM, Lene Fischer < [hidden email] > wrote: <blockquote style='border-left:2px solid #CCCCCC;padding:0 1em' class="gmail_quote" style="margin:0 0 0 .8ex;border-left:1px #ccc solid;padding-left:1ex">
Please first update to 2.6.1.
If you have your crashed projects – you also have projects named with a .qgs~. Rename this project and delete the ~ and open it as usual.
A lot of my students had the same problem last week – but only the ones who had forgotten to update to 2.6.1
Hope this can help you.
Regards
Lene Fischer
Associate Professor
Department of Geosciences and Natural Resource Management
University of Copenhagen
MOB <a href="tel:%2B45%2040115084" value="+4540115084" target="_blank">+45 40115084
[hidden email]
Fra: [hidden email] [mailto: [hidden email] ]
På vegne af Matt Boyd
Sendt: 26. januar 2015 23:29
Til: qgis-user
Emne: [Qgis-user] Fwd: QGIS crash on loading projects
Just a bump to this question, does anyone know how to enable logging or find the log file? I really don't want to have to re create all my project files and I can't get any of the my old projects to open.
On Fri, Jan 23, 2015 at 3:09 PM, Matt Boyd < [hidden email] > wrote:
On Fri, Jan 23, 2015 at 2:58 PM, Nicolas Cadieux < [hidden email] > wrote:
If you had and "openlayer" opened (like google earth or bing map), but but did not reinstall the plugin, it can crash. Try installing that plugin and see what happens...
Nope, that doesn't help.
<blockquote style='border-left:2px solid #CCCCCC;padding:0 1em' style="border:none;border-left:solid #cccccc 1.0pt;padding:0cm 0cm 0cm 6.0pt;margin-left:4.8pt;margin-right:0cm">
Téléphone: <a href="tel:514.381.5112" target="_blank">514.381.5112 Fax: <a href="tel:514.381.4995" target="_blank">
514.381.4995
Le 2015-01-22 22:46, "Matt Boyd [via OSGeo.org]" < [hidden email] > a écrit :
woops, forgot,
windows 7 64 bit,
qgis 2.6 installed via osgeo4w64
On Fri, Jan 23, 2015 at 2:45 PM, Matt Boyd < [hidden email] > wrote:
Hi QGISers,
for some reason today I can't load saved QGIS projects. QGIS crashes at abour 95% loaded with no information in the notification about why.
I've tried reinstall from osgeo4w64, reboot, start from command line, disabling all plugins.
Where's the log file kept and is there a way to enable logging from the osgeo cl window in windows 7?
About the only thing that's different today is a few updates, one of them being a .NET windows update.
Thanks
Matt
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183269.html
To start a new topic under Quantum GIS - User, email
[hidden email]
To unsubscribe from Quantum GIS - User, click here.
NAML
View this message in context:
Re: QGIS crash on loading projects
Sent from the
Quantum GIS - User mailing list archive at Nabble.com.
[hidden email]
[hidden email]
http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183855.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183862.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150126/8044a0d2/attachment.html>
