[Qgis-user] Fwd: QGIS crash on loading projects
Matt Boyd
mattslists at gmail.com
Mon Jan 26 15:17:11 PST 2015
Thanks Lene,
I tried that on a 3 projects this morning with no change to the behaviour.
I've had 2.6.1 for a while now and these projects opened in that early last
week.
I've also tried loading older projects that are still in 2.0, 2.2, and 2.4
format and the same thing happens.
Most of my projects are on a network drive and I've managed to get a step
further by copying those project files to a local drive. I then get the
"handle bad layers" dialog, then qgis crashes. I need to dig a little to
see if this is a problem in case someone has moved some of the layers the
dialog is referring to but this hasn't caused a crash before.
Is this behaviour logged anywhere?
Thanks
Mat
On Tue, Jan 27, 2015 at 9:58 AM, Lene Fischer <lfi at ign.ku.dk> wrote:
> Please first update to 2.6.1.
> If you have your crashed projects – you also have projects named with a
> .qgs~. Rename this project and delete the ~ and open it as usual.
> A lot of my students had the same problem last week – but only the ones
> who had forgotten to update to 2.6.1
> Hope this can help you.
> Regards
> *Lene Fischer*
> Associate Professor
> *Department of Geosciences and Natural Resource Management*
> University of Copenhagen
> MOB +45 40115084
> lfi at ign.ku.dk
> [image: cid:image001.gif at 01D03029.2F3EC6A0]
> *Fra:* qgis-user-bounces at lists.osgeo.org [mailto:
> qgis-user-bounces at lists.osgeo.org] *På vegne af *Matt Boyd
> *Sendt:* 26. januar 2015 23:29
> *Til:* qgis-user
> *Emne:* [Qgis-user] Fwd: QGIS crash on loading projects
> Just a bump to this question, does anyone know how to enable logging or
> find the log file? I really don't want to have to re create all my project
> files and I can't get any of the my old projects to open.
> On Fri, Jan 23, 2015 at 3:09 PM, Matt Boyd <mattslists at gmail.com> wrote:
> On Fri, Jan 23, 2015 at 2:58 PM, Nicolas Cadieux <
> nicolas.cadieux at archeotec.ca> wrote:
> Hi,
> If you had and "openlayer" opened (like google earth or bing map), but but
> did not reinstall the plugin, it can crash. Try installing that plugin and
> see what happens...
> Nope, that doesn't help.
> Nicolas Cadieux M.Sc.
> Les Entreprises Archéotec inc.
> 8548, rue Saint-Denis Montréal H2P 2H2
> Téléphone: 514.381.5112 Fax: 514.381.4995
> Le 2015-01-22 22:46, "Matt Boyd [via OSGeo.org]" <[hidden email]
> <http://user/SendEmail.jtp?type=node&node=5183270&i=0>> a écrit :
> woops, forgot,
> windows 7 64 bit,
> qgis 2.6 installed via osgeo4w64
> On Fri, Jan 23, 2015 at 2:45 PM, Matt Boyd <[hidden email]
> <http://user/SendEmail.jtp?type=node&node=5183269&i=0>> wrote:
> Hi QGISers,
> for some reason today I can't load saved QGIS projects. QGIS crashes at
> abour 95% loaded with no information in the notification about why.
> I've tried reinstall from osgeo4w64, reboot, start from command line,
> disabling all plugins.
> Where's the log file kept and is there a way to enable logging from the
> osgeo cl window in windows 7?
> About the only thing that's different today is a few updates, one of them
> being a .NET windows update.
> Thanks
> Matt
> Qgis-user mailing list
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5183269&i=1>
> *If you reply to this email, your message will be added to the discussion
> below:*
> http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183269.html
> To start a new topic under Quantum GIS - User, email [hidden email]
> <http://user/SendEmail.jtp?type=node&node=5183270&i=1>
> To unsubscribe from Quantum GIS - User, click here.
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> View this message in context: Re: QGIS crash on loading projects
> <http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183270.html>
> Sent from the Quantum GIS - User mailing list archive
> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html> at
> Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150127/22cc618e/attachment.html>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150127/22cc618e/attachment.gif>
