[Qgis-user] WFS-T update to geoserver fails
    emmexx
    emmexx at tiscalinet.it
    Tue Jan 27 05:16:40 PST 2015
I load a wfs-t layer hosted on a geoserver server and add or modify a
feature.
When I save the layer, qgis timeouts, the layer is not updated on the
server and I have to restart geoserver in order to be able to load it
again in qgis (and elesewhere too).
The qgis error is:
Could not commit changes to layer xxx
Errors: ERROR: 1(s) feature not added
Provider errors:
   Empty response
I found something similar described here:
[[http://gis.stackexchange.com/questions/115471/qgis-wfs-error-could-not-commit-changes-to-layer]]
[[http://jira.codehaus.org/browse/GEOS-6059]]
Trying to understand what was wrong in the qgis call (update of a
feature or new feature added) I used netTool. This program has a tunnel
feature that acts as a MITM between an application and a remote server.
So I changed the wfs address in qgis from:
http://mywebsite:8080/geoserver/wfs to
http://localhost:7000/geoserver/wfs and set netTool to tunnel to
I updated a feature value, saved and to my great surprise everything
worked fine.
After filing a bug in qgis I was suggested to try to connect to another
geoserver. I started osgeo live 8 on another pc on my local network,
from my desktop I started qgis, added a WFS layer from geoserver on
osgeo live 8, updated a feature and everything worked fine.
So I'm asking here for help.
I asked for help on the geoserver mailing list but since I'm using the
boundless opengeo versione, they can't help.
I just want to understand if this is a geoserver only problem or if it
derives from the interaction of qgis and geoserver.
Why does netTool makes everything work fine?
Why can a call from qgis hang geoserver (the wfs service of...)?
Any help would be appreciated.
	maxx
QGIS version    2.6.1-Brighton    QGIS code revision    exported
Compiled against Qt    4.8.5    Running against Qt    4.8.5
Compiled against GDAL/OGR    1.11.0    Running against GDAL/OGR    1.11.0
Compiled against GEOS    3.3.8-CAPI-1.7.8    Running against GEOS
3.3.8-CAPI-1.7.8
PostgreSQL Client Version    No support.    SpatiaLite Version    4.0.0
QWT Version    5.1.1    PROJ.4 Version    480
QScintilla2 Version    2.6.1
Geoserver is version 2.5 snapshot installed from boundless opengeo suite 4.1
