[Qgis-user] Nodata and raster calculator
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Tue Jan 27 11:48:36 PST 2015
Salut JF,
What you are seeing is normal behavior.
The "3.xxx e-38" is, like you say, the normal float default. So your
question is about the 0.
When you create and expression like
("Montmorency_DSM_NN5m_17x17_mean11 at 1" <= -0.005 OR
Montmorency_DSM_NN5m_17x17_mean11 at 1" >= -0.005 ),  this gives you a
layer with pixels having the value of "1" (satisfies condition) or "0"
(does not satisfy condition).  If you want more then just a layer with
"1" and "0" , you multiply the result (a layer kept in memory) by the
original layer (...*"Montmorency_DSM_NN5m_17x17_mean11 at 1").  Therefore,
whatever pixel that had a "1", now takes on a new value (from the
Montmorency layer) and any pixel that had a "0" keeps the zero value.
If you want "0" to become a "NULL" value, you must do it manually by
doing a "save as" and adding "0" to the no value data.  You can also add
and additional no data value under "Layer property/Transparency/No data
value/Additional value."  This will affect sytle and transparency but
not raster math (to my knowledge).
I can be reached in  Montréal if you have question.
Bonne chance
Nicolas
514-987-6253
Le 2015-01-27 14:10, jfprieur [via OSGeo.org] a écrit :
> Still get the same error, the masked value is set to 0 while the
> nodata for the new raster is the usual float default of 3.xxx e-38
> Starting to wonder if it is not something stupid like the fact that
> the french decimal separator is a comma instead of a period or
> something like that. I tried multiplying by 1.0 in my raster
> calculator expression to try to force it to the float nodata but same
> result.
> https://docs.google.com/document/d/1_-o9VcjEiyKigyk3xwi1zvxWi_o9NaoQy5XOMakik84/edit?usp=sharing
> If you reply to this email, your message will be added to the
> discussion below:
> http://osgeo-org.1560.x6.nabble.com/Nodata-and-raster-calculator-tp5182962p5184028.html
> To start a new topic under Quantum GIS - User, email
> ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, click here
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg==>.
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.x6.nabble.com/Nodata-and-raster-calculator-tp5182962p5184034.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150127/6163b947/attachment.html>
