[Qgis-user] Zoom settings
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Wed Jan 28 04:37:22 PST 2015
Hi
I suspect that you are using the Open Layers plug-in?
I would  try to avoid it, cause there are some issues.
1. It changes your coordinate system to Google Mercator to adopt to the
tile format. Changing back the original CRS is possible, but opens a can
of worms and digitizing then in another CRS will lead to misaligned
features.
2. At least with Google maps (and Bing?), at a certain scale and for some
regions, the service switches from satellite view to a side view (check in
your browser for your region). That's possibly the reason why you don't
get images delivered in smaller scales.
Better try to find other WMS services and use them directly.
Don't know if my answer is totally correct, cause I don't use the Open
Layers plugin ;)
Cheers
Bernd
Am 28.01.2015, 12:17 Uhr, schrieb massimo.figaroli
<massimo.figaroli at gmail.com>:
> Hi everybody!
> I'm using QGIS 2.4.0 Chugiak and I have some trouble with the "zoom".
> I'm not able to perform zoom under 1: 2.256.
> I'm working in EPSG 32632... I thought that this problem occurred working
> with tile map (OSM, Google Maps) as preset maximum value.
> How can I perform a 1:100 zoomed view, for example?
> Thanks so much for your help,
> Massimo
> http://osgeo-org.1560.x6.nabble.com/Zoom-settings-tp5184149.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
Bernd Vogelgesang
Siedlerstraße 2
91083 Baiersdorf/Igelsdorf
Tel: 09133-825374
