[Qgis-user] Fwd: QGIS crash on loading projects
Matt Boyd
mattslists at gmail.com
Wed Jan 28 18:04:34 PST 2015
This is getting frustrating, would this be worth contacting the devs about?
I haven't made any progress with this issue.
On Wed, Jan 28, 2015 at 10:24 AM, Matt Boyd <mattslists at gmail.com> wrote:
> Still no luck, I've generated a log file of a crash that I don't see
> anything useful in.
> http://pastebin.com/UhuvQA4k
> On Wed, Jan 28, 2015 at 8:52 AM, Matt Boyd <mattslists at gmail.com> wrote:
>> Thanks for all the help everyone.
>> I think I've narrowed it down to something with Print Composer. As soon
>> as I try to start a new print composer window the project crashes. This
>> happens even with newly created projects.
>> The problem with other projects loading must be because most of them have
>> a print composer window to open.
>> Now more digging.
>> Thanks again.
>> On Wed, Jan 28, 2015 at 12:01 AM, Nicolas Cadieux <
>> nicolas.cadieux at archeotec.ca> wrote:
>>> Hi,
>>> Have you tried to open the projects with a different computer? Send a
>>> simple project along and maybe we can look at it. Are all new projects
>>> working perfectly?
>>> Nicolas Cadieux M.Sc.
>>> Les Entreprises Archéotec inc.
>>> 8548, rue Saint-Denis Montréal H2P 2H2
>>> Téléphone: 514.381.5112 Fax: 514.381.4995
>>> Le 2015-01-27 01:31, "Matt Boyd [via OSGeo.org]" <[hidden email]
>>> <http:///user/SendEmail.jtp?type=node&node=5183947&i=0>> a écrit :
>>> Complete reinstall third time lucky, QGIS runs. It still crashes when I
>>> try to open an older project so I'm back to where I was this morning.
>>> I would really appreciate knowing if there is a log file generated or
>>> how to create one?
>>> On Tue, Jan 27, 2015 at 4:05 PM, Matt Boyd <[hidden email]
>>> <http:///user/SendEmail.jtp?type=node&node=5183884&i=0>> wrote:
>>> On Tue, Jan 27, 2015 at 11:17 AM, Nicolas Cadieux <[hidden email]
>>> <http:///user/SendEmail.jtp?type=node&node=5183884&i=1>> wrote:
>>> Hi,
>>> Personally this is what I would do.
>>> Completely purges Qgis from your system. (Delete plugin directories,
>>> AND the Qgis registry keys.) Reboot.
>>> I would install Qgis 2.6.1 using the OSGEO install.
>>> I followed these steps. My install was already done via osge064w and
>>> uninstalling was a little tricky.
>>> I removed the directories and the registry entries.
>>> I then reinstalled QGIS via the express installer.
>>> QGIS wouldn't start giving an error about jvm.dll missing from my
>>> computer.
>>> I manually selected the java install via the advanced option, jvm is
>>> installed and in a subfolder in C:\osgeo4w64
>>> I suspect it's a path problem, working on this.
>>> I would make sure that all mapped drive are properly remapped with the
>>> proper passwords, I would install the open layer plugin and wms or other
>>> data servers. Make sure the symbols are reinstalled if you had new ones and
>>> also make sure the .svg symbol images are well mapped.
>>> If the problem persists, I would repurge Qgis, install and older version
>>> and try again.
>>> Finally, i would then start looking at the project files with a text
>>> editor to try to understand the problem. I is likely the crash is cause by
>>> a layer that cannot be opened and that this layer depends on a plugin like
>>> openlayer, a mapped drive, wms servers... That would be my guess.
>>> Téléphone: <a href="tel:514.381.5112" value="+15143815112"
>>> target="_blank">514.381.5112 Fax: <a href="tel:514.381.4995" value="
>>> +15143814995" target="_blank">514.381.4995
>>> Le 2015-01-26 18:16, "Matt Boyd [via OSGeo.org]" <[hidden email]
>>> <http:///user/SendEmail.jtp?type=node&node=5183862&i=0>> a écrit :
>>> Thanks Lene,
>>> I tried that on a 3 projects this morning with no change to the
>>> behaviour. I've had 2.6.1 for a while now and these projects opened in that
>>> early last week.
>>> I've also tried loading older projects that are still in 2.0, 2.2, and
>>> 2.4 format and the same thing happens.
>>> Most of my projects are on a network drive and I've managed to get a
>>> step further by copying those project files to a local drive. I then get
>>> the "handle bad layers" dialog, then qgis crashes. I need to dig a little
>>> to see if this is a problem in case someone has moved some of the layers
>>> the dialog is referring to but this hasn't caused a crash before.
>>> Is this behaviour logged anywhere?
>>> Thanks
>>> Mat
>>> On Tue, Jan 27, 2015 at 9:58 AM, Lene Fischer <[hidden email]
>>> <http:///user/SendEmail.jtp?type=node&node=5183855&i=0>> wrote:
>>> Please first update to 2.6.1.
>>> If you have your crashed projects – you also have projects named with a
>>> .qgs~. Rename this project and delete the ~ and open it as usual.
>>> A lot of my students had the same problem last week – but only the ones
>>> who had forgotten to update to 2.6.1
>>> Hope this can help you.
>>> Regards
>>> *Lene Fischer*
>>> Associate Professor
>>> *Department of Geosciences and Natural Resource Management*
>>> University of Copenhagen
>>> MOB <a href="tel:%2B45%2040115084" value="<a href="tel:%2B4540115084"
>>> value="+4540115084" target="_blank">+4540115084" target="_blank"><a
>>> href="tel:%2B45%2040115084" value="+4540115084" target="_blank">+45
>>> 40115084
>>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5183855&i=1>
>>> [image: cid:image001.gif at 01D03029.2F3EC6A0]
>>> *Fra:* [hidden email]
>>> <http:///user/SendEmail.jtp?type=node&node=5183855&i=2> [mailto:[hidden
>>> email] <http:///user/SendEmail.jtp?type=node&node=5183855&i=3>] *På
>>> vegne af *Matt Boyd
>>> *Sendt:* 26. januar 2015 23:29
>>> *Til:* qgis-user
>>> *Emne:* [Qgis-user] Fwd: QGIS crash on loading projects
>>> Just a bump to this question, does anyone know how to enable logging or
>>> find the log file? I really don't want to have to re create all my project
>>> files and I can't get any of the my old projects to open.
>>> On Fri, Jan 23, 2015 at 3:09 PM, Matt Boyd <[hidden email]
>>> <http:///user/SendEmail.jtp?type=node&node=5183855&i=4>> wrote:
>>> On Fri, Jan 23, 2015 at 2:58 PM, Nicolas Cadieux <[hidden email]
>>> <http:///user/SendEmail.jtp?type=node&node=5183855&i=5>> wrote:
>>> Hi,
>>> If you had and "openlayer" opened (like google earth or bing map), but
>>> but did not reinstall the plugin, it can crash. Try installing that plugin
>>> and see what happens...
>>> Nope, that doesn't help.
>>> Téléphone: <a href="tel:<a href="tel:514.381.5112" value="+15143815112"
>>> target="_blank">514.381.5112" target="_blank"><a href="tel:514.381.5112"
>>> value="+15143815112" target="_blank">514.381.5112 Fax: <a href="tel:<a
>>> href="tel:514.381.4995" value="+15143814995" target="_blank">
>>> 514.381.4995" target="_blank"> <a href="tel:514.381.4995" value="
>>> Le 2015-01-22 22:46, "Matt Boyd [via OSGeo.org]" <[hidden email]
>>> <http://user/SendEmail.jtp?type=node&node=5183270&i=0>> a écrit :
>>> woops, forgot,
>>> windows 7 64 bit,
>>> qgis 2.6 installed via osgeo4w64
>>> On Fri, Jan 23, 2015 at 2:45 PM, Matt Boyd <[hidden email]
>>> <http://user/SendEmail.jtp?type=node&node=5183269&i=0>> wrote:
>>> Hi QGISers,
>>> for some reason today I can't load saved QGIS projects. QGIS crashes at
>>> abour 95% loaded with no information in the notification about why.
>>> I've tried reinstall from osgeo4w64, reboot, start from command line,
>>> disabling all plugins.
>>> Where's the log file kept and is there a way to enable logging from the
>>> osgeo cl window in windows 7?
>>> About the only thing that's different today is a few updates, one of
>>> them being a .NET windows update.
>>> Thanks
>>> Matt
>>> Qgis-user mailing list
>>> [hidden email] <http://user/SendEmail.jtp?type=node&node=5183269&i=1>
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> *If you reply to this email, your message will be added to the
>>> discussion below:*
>>> http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183269.html
>>> To start a new topic under Quantum GIS - User, email [hidden email]
>>> <http://user/SendEmail.jtp?type=node&node=5183270&i=1>
>>> To unsubscribe from Quantum GIS - User, click here.
>>> NAML
>>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
>>> View this message in context: Re: QGIS crash on loading projects
>>> <http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183270.html>
>>> Sent from the Quantum GIS - User mailing list archive
>>> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html> at
>>> Nabble.com.
>>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5183855&i=6>
>>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5183855&i=7>
>>> discussion below:
>>> http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183855.html
>>> <http:///user/SendEmail.jtp?type=node&node=5183862&i=1>
>>> NAML
>>> View this message in context: Re: Fwd: QGIS crash on loading projects
>>> <http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183862.html>
>>> Nabble.com.
>>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5183884&i=2>
>>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5183884&i=3>
>>> discussion below:
>>> http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183884.html
>>> <http:///user/SendEmail.jtp?type=node&node=5183947&i=1>
>>> NAML
>>> <http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183947.html>
>>> Nabble.com.
>>> Qgis-user at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150129/c0ac80c8/attachment.html>
