[Qgis-user] Fwd: QGIS crash on loading projects
Matt Boyd mattslists at gmail.com
Wed Jan 28 18:44:42 PST 2015
Hi Nathan,
I've done this with a test project and as soon as open a map composer QGIS
crashes.
Open QGIS into new blank project
Open print composer, select create new print composer window, press the OK
button
Crash
adjust projection etc, add layers to project
button
Crash
Open older QGIS project with previously created map windows / compositions.
layers start to load
Crash.
Seems like my problem is the print composer and is unrelated to any of the
projects I have saved. I am able to open them on another PC.
I've tried a complete uninstall and reinstall of QGIS and all of the
OSGEO4W64 components, deleting my .qgis user directory. (this took some
figuring out as the uninstall isn't a transparent process)
Standalone install of QGIS 2.6.1 from website download.
Standalone install of QGIS 2.4 from website download.
In none of the above cases am I able to get the print composer to start. I
really don't want to have to reinstall windows.
Thanks
Matt
On Thu, Jan 29, 2015 at 1:29 PM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> Hey Matt,
> What kind of layers do you have in the project?
> On Thu, 29 Jan 2015 12:05 pm Matt Boyd <mattslists at gmail.com> wrote:
>> This is getting frustrating, would this be worth contacting the devs
>> about? I haven't made any progress with this issue.
>> On Wed, Jan 28, 2015 at 10:24 AM, Matt Boyd <mattslists at gmail.com> wrote:
>>> Still no luck, I've generated a log file of a crash that I don't see
>>> anything useful in.
>>> http://pastebin.com/UhuvQA4k
>>> On Wed, Jan 28, 2015 at 8:52 AM, Matt Boyd <mattslists at gmail.com> wrote:
>>>> Thanks for all the help everyone.
>>>> I think I've narrowed it down to something with Print Composer. As soon
>>>> as I try to start a new print composer window the project crashes. This
>>>> happens even with newly created projects.
>>>> The problem with other projects loading must be because most of them
>>>> have a print composer window to open.
>>>> Now more digging.
>>>> Thanks again.
>>>> On Wed, Jan 28, 2015 at 12:01 AM, Nicolas Cadieux <
>>>> nicolas.cadieux at archeotec.ca> wrote:
>>>>> Hi,
>>>>> Have you tried to open the projects with a different computer?  Send a
>>>>> simple project along and maybe we can look at it.  Are all new projects
>>>>> working perfectly?
>>>>> Nicolas Cadieux M.Sc.
>>>>> Les Entreprises Archéotec inc.
>>>>> 8548, rue Saint-Denis Montréal H2P 2H2
>>>>> Téléphone: 514.381.5112  Fax: 514.381.4995
>>>>> Le 2015-01-27 01:31, "Matt Boyd [via OSGeo.org]" <[hidden email]
>>>>> <http:///user/SendEmail.jtp?type=node&node=5183947&i=0>> a écrit :
>>>>> Complete reinstall third time lucky, QGIS runs. It still crashes when
>>>>> I try to open an older project so I'm back to where I was this morning.
>>>>> I would really appreciate knowing if there is a log file generated or
>>>>> how to create one?
>>>>> On Tue, Jan 27, 2015 at 4:05 PM, Matt Boyd <[hidden email]
>>>>> <http:///user/SendEmail.jtp?type=node&node=5183884&i=0>> wrote:
>>>>> On Tue, Jan 27, 2015 at 11:17 AM, Nicolas Cadieux <[hidden email]
>>>>> <http:///user/SendEmail.jtp?type=node&node=5183884&i=1>> wrote:
>>>>> Hi,
>>>>> Personally this is what I would do.
>>>>> Completely purges Qgis from your system.  (Delete plugin directories,
>>>>> AND the Qgis registry keys.) Reboot.
>>>>> I would install Qgis 2.6.1 using the OSGEO install.
>>>>> I followed these steps. My install was already done via osge064w and
>>>>> uninstalling was a little tricky.
>>>>> I removed the directories and the registry entries.
>>>>> I then reinstalled QGIS via the express installer.
>>>>> QGIS wouldn't start giving an error about jvm.dll missing from my
>>>>> computer.
>>>>> I manually selected the java install via the advanced option, jvm is
>>>>> installed and in a subfolder in C:\osgeo4w64
>>>>> I suspect it's a path problem, working on this.
>>>>> I would make sure that all mapped drive are properly remapped with the
>>>>> proper passwords, I would install the open layer plugin and wms or other
>>>>> data servers. Make sure the symbols are reinstalled if you had new ones and
>>>>> also make sure the .svg symbol images are well mapped.
>>>>> If the problem persists, I would repurge Qgis, install and older
>>>>> version and try again.
>>>>> Finally, i would then start looking at the project files with a text
>>>>> editor to try to  understand the problem. I is likely the crash is cause by
>>>>> a layer that cannot be opened and that this layer depends on a plugin like
>>>>> openlayer, a mapped drive, wms servers... That would be my guess.
>>>>> Téléphone: <a href="tel:514.381.5112" value="+15143815112"
>>>>> target="_blank">514.381.5112  Fax: <a href="tel:514.381.4995" value="
>>>>> +15143814995" target="_blank">514.381.4995
>>>>> Le 2015-01-26 18:16, "Matt Boyd [via OSGeo.org]" <[hidden email]
>>>>> <http:///user/SendEmail.jtp?type=node&node=5183862&i=0>> a écrit :
>>>>> Thanks Lene,
>>>>> I tried that on a 3 projects this morning with no change to the
>>>>> behaviour. I've had 2.6.1 for a while now and these projects opened in that
>>>>> early last week.
>>>>> I've also tried loading older projects that are still in 2.0, 2.2, and
>>>>> 2.4 format and the same thing happens.
>>>>> Most of my projects are on a network drive and I've managed to get a
>>>>> step further by copying those project files to a local drive. I then get
>>>>> the "handle bad layers" dialog, then qgis crashes. I need to dig a little
>>>>> to see if this is a problem in case someone has moved some of the layers
>>>>> the dialog is referring to but this hasn't caused a crash before.
>>>>> Is this behaviour logged anywhere?
>>>>> Thanks
>>>>> Mat
>>>>> On Tue, Jan 27, 2015 at 9:58 AM, Lene Fischer <[hidden email]
>>>>> <http:///user/SendEmail.jtp?type=node&node=5183855&i=0>> wrote:
>>>>> Please first update to 2.6.1.
>>>>> If you have your crashed projects – you also have projects named with
>>>>> a .qgs~. Rename this project and delete the ~  and open it as usual.
>>>>> A lot of my students had the same problem last week – but only the
>>>>> ones who had forgotten to update to 2.6.1
>>>>> Hope this can help you.
>>>>> Regards
>>>>> *Lene Fischer*
>>>>> Associate Professor
>>>>> *Department of Geosciences and Natural Resource Management*
>>>>> University of Copenhagen
>>>>> MOB <a href="tel:%2B45%2040115084" value="<a href="tel:%2B4540115084"
>>>>> value="+4540115084" target="_blank">+4540115084" target="_blank"><a
>>>>> href="tel:%2B45%2040115084" value="+4540115084" target="_blank">+45
>>>>> 40115084
>>>>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5183855&i=1>
>>>>> [image: cid:image001.gif at 01D03029.2F3EC6A0]
>>>>> *Fra:* [hidden email]
>>>>> <http:///user/SendEmail.jtp?type=node&node=5183855&i=2> [mailto:[hidden
>>>>> email] <http:///user/SendEmail.jtp?type=node&node=5183855&i=3>] *På
>>>>> vegne af *Matt Boyd
>>>>> *Sendt:* 26. januar 2015 23:29
>>>>> *Til:* qgis-user
>>>>> *Emne:* [Qgis-user] Fwd: QGIS crash on loading projects
>>>>> Just a bump to this question, does anyone know how to enable logging
>>>>> or find the log file? I really don't want to have to re create all my
>>>>> project files and I can't get any of the my old projects to open.
>>>>> On Fri, Jan 23, 2015 at 3:09 PM, Matt Boyd <[hidden email]
>>>>> <http:///user/SendEmail.jtp?type=node&node=5183855&i=4>> wrote:
>>>>> On Fri, Jan 23, 2015 at 2:58 PM, Nicolas Cadieux <[hidden email]
>>>>> <http:///user/SendEmail.jtp?type=node&node=5183855&i=5>> wrote:
>>>>> Hi,
>>>>> If you had and "openlayer" opened (like google earth or bing map), but
>>>>> but did not reinstall the plugin, it can crash.  Try installing that plugin
>>>>> and see what happens...
>>>>> Nope, that doesn't help.
>>>>> Téléphone: <a href="tel:<a href="tel:514.381.5112" value="+15143815112"
>>>>> target="_blank">514.381.5112" target="_blank"><a href="tel:
>>>>> 514.381.5112" value="+15143815112" target="_blank">514.381.5112  Fax:
>>>>> <a href="tel:<a href="tel:514.381.4995" value="+15143814995"
>>>>> target="_blank">514.381.4995" target="_blank"> <a href="tel:
>>>>> 514.381.4995" value="+15143814995" target="_blank">514.381.4995
>>>>> Le 2015-01-22 22:46, "Matt Boyd [via OSGeo.org]" <[hidden email]
>>>>> <http://user/SendEmail.jtp?type=node&node=5183270&i=0>> a écrit :
>>>>> woops, forgot,
>>>>> windows 7 64 bit,
>>>>> qgis 2.6 installed via osgeo4w64
>>>>> On Fri, Jan 23, 2015 at 2:45 PM, Matt Boyd <[hidden email]
>>>>> <http://user/SendEmail.jtp?type=node&node=5183269&i=0>> wrote:
>>>>> Hi QGISers,
>>>>> for some reason today I can't load saved QGIS projects. QGIS crashes
>>>>> at abour 95% loaded with no information in the notification about why.
>>>>> I've tried reinstall from osgeo4w64, reboot, start from command line,
>>>>> disabling all plugins.
>>>>> Where's the log file kept and is there a way to enable logging from
>>>>> the osgeo cl window in windows 7?
>>>>> About the only thing that's different today is a few updates, one of
>>>>> them being a .NET windows update.
>>>>> Thanks
>>>>> Matt
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> [hidden email] <http://user/SendEmail.jtp?type=node&node=5183269&i=1>
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> *If you reply to this email, your message will be added to the
>>>>> discussion below:*
>>>>> http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183269.html
>>>>> To start a new topic under Quantum GIS - User, email [hidden email]
>>>>> <http://user/SendEmail.jtp?type=node&node=5183270&i=1>
>>>>> To unsubscribe from Quantum GIS - User, click here.
>>>>> NAML
>>>>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
>>>>> View this message in context: Re: QGIS crash on loading projects
>>>>> <http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183270.html>
>>>>> Sent from the Quantum GIS - User mailing list archive
>>>>> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html>
>>>>> at Nabble.com.
>>>>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5183855&i=6>
>>>>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5183855&i=7>
>>>>> discussion below:
>>>>> http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183855.html
>>>>> <http:///user/SendEmail.jtp?type=node&node=5183862&i=1>
>>>>> NAML
>>>>> View this message in context: Re: Fwd: QGIS crash on loading projects
>>>>> <http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183862.html>
>>>>> at Nabble.com.
>>>>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5183884&i=2>
>>>>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5183884&i=3>
>>>>> discussion below:
>>>>> http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183884.html
>>>>> <http:///user/SendEmail.jtp?type=node&node=5183947&i=1>
>>>>> NAML
>>>>> <http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183947.html>
>>>>> at Nabble.com.
>>>>> Qgis-user at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150129/f2390850/attachment.html>
