[Qgis-user] Fwd: QGIS crash on loading projects
Nathan Woodrow madmanwoo at gmail.com
Wed Jan 28 18:29:55 PST 2015
Hey Matt,
What kind of layers do you have in the project?
On Thu, 29 Jan 2015 12:05 pm Matt Boyd <mattslists at gmail.com> wrote:
> This is getting frustrating, would this be worth contacting the devs
> about? I haven't made any progress with this issue.
> On Wed, Jan 28, 2015 at 10:24 AM, Matt Boyd <mattslists at gmail.com> wrote:
>> Still no luck, I've generated a log file of a crash that I don't see
>> anything useful in.
>> http://pastebin.com/UhuvQA4k
>> On Wed, Jan 28, 2015 at 8:52 AM, Matt Boyd <mattslists at gmail.com> wrote:
>>> Thanks for all the help everyone.
>>> I think I've narrowed it down to something with Print Composer. As soon
>>> as I try to start a new print composer window the project crashes. This
>>> happens even with newly created projects.
>>> The problem with other projects loading must be because most of them
>>> have a print composer window to open.
>>> Now more digging.
>>> Thanks again.
>>> On Wed, Jan 28, 2015 at 12:01 AM, Nicolas Cadieux <
>>> nicolas.cadieux at archeotec.ca> wrote:
>>>> Hi,
>>>> Have you tried to open the projects with a different computer?  Send a
>>>> simple project along and maybe we can look at it.  Are all new projects
>>>> working perfectly?
>>>> Nicolas Cadieux M.Sc.
>>>> Les Entreprises Archéotec inc.
>>>> 8548, rue Saint-Denis Montréal H2P 2H2
>>>> Téléphone: 514.381.5112  Fax: 514.381.4995
>>>> Le 2015-01-27 01:31, "Matt Boyd [via OSGeo.org]" <[hidden email]
>>>> <http:///user/SendEmail.jtp?type=node&node=5183947&i=0>> a écrit :
>>>> Complete reinstall third time lucky, QGIS runs. It still crashes when I
>>>> try to open an older project so I'm back to where I was this morning.
>>>> I would really appreciate knowing if there is a log file generated or
>>>> how to create one?
>>>> On Tue, Jan 27, 2015 at 4:05 PM, Matt Boyd <[hidden email]
>>>> <http:///user/SendEmail.jtp?type=node&node=5183884&i=0>> wrote:
>>>> On Tue, Jan 27, 2015 at 11:17 AM, Nicolas Cadieux <[hidden email]
>>>> <http:///user/SendEmail.jtp?type=node&node=5183884&i=1>> wrote:
>>>> Hi,
>>>> Personally this is what I would do.
>>>> Completely purges Qgis from your system.  (Delete plugin directories,
>>>> AND the Qgis registry keys.) Reboot.
>>>> I would install Qgis 2.6.1 using the OSGEO install.
>>>> I followed these steps. My install was already done via osge064w and
>>>> uninstalling was a little tricky.
>>>> I removed the directories and the registry entries.
>>>> I then reinstalled QGIS via the express installer.
>>>> QGIS wouldn't start giving an error about jvm.dll missing from my
>>>> computer.
>>>> I manually selected the java install via the advanced option, jvm is
>>>> installed and in a subfolder in C:\osgeo4w64
>>>> I suspect it's a path problem, working on this.
>>>> I would make sure that all mapped drive are properly remapped with the
>>>> proper passwords, I would install the open layer plugin and wms or other
>>>> data servers. Make sure the symbols are reinstalled if you had new ones and
>>>> also make sure the .svg symbol images are well mapped.
>>>> If the problem persists, I would repurge Qgis, install and older
>>>> version and try again.
>>>> Finally, i would then start looking at the project files with a text
>>>> editor to try to  understand the problem. I is likely the crash is cause by
>>>> a layer that cannot be opened and that this layer depends on a plugin like
>>>> openlayer, a mapped drive, wms servers... That would be my guess.
>>>> Téléphone: <a href="tel:514.381.5112" value="+15143815112"
>>>> target="_blank">514.381.5112  Fax: <a href="tel:514.381.4995" value="
>>>> +15143814995" target="_blank">514.381.4995
>>>> Le 2015-01-26 18:16, "Matt Boyd [via OSGeo.org]" <[hidden email]
>>>> <http:///user/SendEmail.jtp?type=node&node=5183862&i=0>> a écrit :
>>>> Thanks Lene,
>>>> I tried that on a 3 projects this morning with no change to the
>>>> behaviour. I've had 2.6.1 for a while now and these projects opened in that
>>>> early last week.
>>>> I've also tried loading older projects that are still in 2.0, 2.2, and
>>>> 2.4 format and the same thing happens.
>>>> Most of my projects are on a network drive and I've managed to get a
>>>> step further by copying those project files to a local drive. I then get
>>>> the "handle bad layers" dialog, then qgis crashes. I need to dig a little
>>>> to see if this is a problem in case someone has moved some of the layers
>>>> the dialog is referring to but this hasn't caused a crash before.
>>>> Is this behaviour logged anywhere?
>>>> Thanks
>>>> Mat
>>>> On Tue, Jan 27, 2015 at 9:58 AM, Lene Fischer <[hidden email]
>>>> <http:///user/SendEmail.jtp?type=node&node=5183855&i=0>> wrote:
>>>> Please first update to 2.6.1.
>>>> If you have your crashed projects – you also have projects named with a
>>>> .qgs~. Rename this project and delete the ~  and open it as usual.
>>>> A lot of my students had the same problem last week – but only the ones
>>>> who had forgotten to update to 2.6.1
>>>> Hope this can help you.
>>>> Regards
>>>> *Lene Fischer*
>>>> Associate Professor
>>>> *Department of Geosciences and Natural Resource Management*
>>>> University of Copenhagen
>>>> MOB <a href="tel:%2B45%2040115084" value="<a href="tel:%2B4540115084"
>>>> value="+4540115084" target="_blank">+4540115084" target="_blank"><a
>>>> href="tel:%2B45%2040115084" value="+4540115084" target="_blank">+45
>>>> 40115084
>>>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5183855&i=1>
>>>> [image: cid:image001.gif at 01D03029.2F3EC6A0]
>>>> *Fra:* [hidden email]
>>>> <http:///user/SendEmail.jtp?type=node&node=5183855&i=2> [mailto:[hidden
>>>> email] <http:///user/SendEmail.jtp?type=node&node=5183855&i=3>] *På
>>>> vegne af *Matt Boyd
>>>> *Sendt:* 26. januar 2015 23:29
>>>> *Til:* qgis-user
>>>> *Emne:* [Qgis-user] Fwd: QGIS crash on loading projects
>>>> Just a bump to this question, does anyone know how to enable logging or
>>>> find the log file? I really don't want to have to re create all my project
>>>> files and I can't get any of the my old projects to open.
>>>> On Fri, Jan 23, 2015 at 3:09 PM, Matt Boyd <[hidden email]
>>>> <http:///user/SendEmail.jtp?type=node&node=5183855&i=4>> wrote:
>>>> On Fri, Jan 23, 2015 at 2:58 PM, Nicolas Cadieux <[hidden email]
>>>> <http:///user/SendEmail.jtp?type=node&node=5183855&i=5>> wrote:
>>>> Hi,
>>>> If you had and "openlayer" opened (like google earth or bing map), but
>>>> but did not reinstall the plugin, it can crash.  Try installing that plugin
>>>> and see what happens...
>>>> Nope, that doesn't help.
>>>> Téléphone: <a href="tel:<a href="tel:514.381.5112" value="+15143815112"
>>>> target="_blank">514.381.5112" target="_blank"><a href="tel:514.381.5112"
>>>> value="+15143815112" target="_blank">514.381.5112  Fax: <a
>>>> href="tel:<a href="tel:514.381.4995" value="+15143814995"
>>>> target="_blank">514.381.4995" target="_blank"> <a href="tel:
>>>> 514.381.4995" value="+15143814995" target="_blank">514.381.4995
>>>> Le 2015-01-22 22:46, "Matt Boyd [via OSGeo.org]" <[hidden email]
>>>> <http://user/SendEmail.jtp?type=node&node=5183270&i=0>> a écrit :
>>>> woops, forgot,
>>>> windows 7 64 bit,
>>>> qgis 2.6 installed via osgeo4w64
>>>> On Fri, Jan 23, 2015 at 2:45 PM, Matt Boyd <[hidden email]
>>>> <http://user/SendEmail.jtp?type=node&node=5183269&i=0>> wrote:
>>>> Hi QGISers,
>>>> for some reason today I can't load saved QGIS projects. QGIS crashes at
>>>> abour 95% loaded with no information in the notification about why.
>>>> I've tried reinstall from osgeo4w64, reboot, start from command line,
>>>> disabling all plugins.
>>>> Where's the log file kept and is there a way to enable logging from the
>>>> osgeo cl window in windows 7?
>>>> About the only thing that's different today is a few updates, one of
>>>> them being a .NET windows update.
>>>> Thanks
>>>> Matt
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> [hidden email] <http://user/SendEmail.jtp?type=node&node=5183269&i=1>
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> *If you reply to this email, your message will be added to the
>>>> discussion below:*
>>>> http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183269.html
>>>> To start a new topic under Quantum GIS - User, email [hidden email]
>>>> <http://user/SendEmail.jtp?type=node&node=5183270&i=1>
>>>> To unsubscribe from Quantum GIS - User, click here.
>>>> NAML
>>>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
>>>> View this message in context: Re: QGIS crash on loading projects
>>>> <http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183270.html>
>>>> Sent from the Quantum GIS - User mailing list archive
>>>> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html>
>>>> at Nabble.com.
>>>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5183855&i=6>
>>>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5183855&i=7>
>>>> discussion below:
>>>> http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183855.html
>>>> <http:///user/SendEmail.jtp?type=node&node=5183862&i=1>
>>>> NAML
>>>> View this message in context: Re: Fwd: QGIS crash on loading projects
>>>> <http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183862.html>
>>>> at Nabble.com.
>>>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5183884&i=2>
>>>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5183884&i=3>
>>>> discussion below:
>>>> http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183884.html
>>>> <http:///user/SendEmail.jtp?type=node&node=5183947&i=1>
>>>> NAML
>>>> <http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183947.html>
>>>> at Nabble.com.
>>>> Qgis-user at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150129/0a22f276/attachment.html>
