[Qgis-user] Fwd: QGIS crash on loading projects
Matt Boyd
mattslists at gmail.com
Wed Jan 28 18:56:10 PST 2015
No, it's still crashing.
On Thu, Jan 29, 2015 at 1:49 PM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> Ok give this a go.
> In the install folder for QGIS there is a file called OSGeo4w.bat. Run
> that and type:
> qgis --optionspath "C:\temp\qgis" --configpath "C:\temp\qgis"
> Both those options take a folder path and will save the settings there.
> These will create a new user home and settings location in temp\qgis. This
> is good for seeing if there is a busted setting in your registry for QGIS.
> Run that command and see if it still crashes.
> - Nathan
> On Thu Jan 29 2015 at 12:44:42 PM Matt Boyd <mattslists at gmail.com> wrote:
>> Hi Nathan,
>> I've done this with a test project and as soon as open a map composer
>> QGIS crashes.
>> Open QGIS into new blank project
>> Open print composer, select create new print composer window, press the
>> OK button
>> Crash
>> adjust projection etc, add layers to project
>> OK button
>> Crash
>> Open older QGIS project with previously created map windows /
>> compositions.
>> layers start to load
>> Crash.
>> Seems like my problem is the print composer and is unrelated to any of
>> the projects I have saved. I am able to open them on another PC.
>> I've tried a complete uninstall and reinstall of QGIS and all of the
>> OSGEO4W64 components, deleting my .qgis user directory. (this took some
>> figuring out as the uninstall isn't a transparent process)
>> Standalone install of QGIS 2.6.1 from website download.
>> Standalone install of QGIS 2.4 from website download.
>> In none of the above cases am I able to get the print composer to start.
>> I really don't want to have to reinstall windows.
>> Thanks
>> Matt
>> On Thu, Jan 29, 2015 at 1:29 PM, Nathan Woodrow <madmanwoo at gmail.com>
>> wrote:
>>> Hey Matt,
>>> What kind of layers do you have in the project?
>>> On Thu, 29 Jan 2015 12:05 pm Matt Boyd <mattslists at gmail.com> wrote:
>>>> This is getting frustrating, would this be worth contacting the devs
>>>> about? I haven't made any progress with this issue.
>>>> On Wed, Jan 28, 2015 at 10:24 AM, Matt Boyd <mattslists at gmail.com>
>>>> wrote:
>>>>> Still no luck, I've generated a log file of a crash that I don't see
>>>>> anything useful in.
>>>>> http://pastebin.com/UhuvQA4k
>>>>> On Wed, Jan 28, 2015 at 8:52 AM, Matt Boyd <mattslists at gmail.com>
>>>>> wrote:
>>>>>> Thanks for all the help everyone.
>>>>>> I think I've narrowed it down to something with Print Composer. As
>>>>>> soon as I try to start a new print composer window the project crashes.
>>>>>> This happens even with newly created projects.
>>>>>> The problem with other projects loading must be because most of them
>>>>>> have a print composer window to open.
>>>>>> Now more digging.
>>>>>> Thanks again.
>>>>>> On Wed, Jan 28, 2015 at 12:01 AM, Nicolas Cadieux <
>>>>>> nicolas.cadieux at archeotec.ca> wrote:
>>>>>>> Hi,
>>>>>>> Have you tried to open the projects with a different computer? Send
>>>>>>> a simple project along and maybe we can look at it. Are all new projects
>>>>>>> working perfectly?
>>>>>>> Nicolas Cadieux M.Sc.
>>>>>>> Les Entreprises Archéotec inc.
>>>>>>> 8548, rue Saint-Denis Montréal H2P 2H2
>>>>>>> Téléphone: 514.381.5112 Fax: 514.381.4995
>>>>>>> Le 2015-01-27 01:31, "Matt Boyd [via OSGeo.org]" <[hidden email]
>>>>>>> <http:///user/SendEmail.jtp?type=node&node=5183947&i=0>> a écrit :
>>>>>>> Complete reinstall third time lucky, QGIS runs. It still crashes
>>>>>>> when I try to open an older project so I'm back to where I was this morning.
>>>>>>> I would really appreciate knowing if there is a log file generated
>>>>>>> or how to create one?
>>>>>>> On Tue, Jan 27, 2015 at 4:05 PM, Matt Boyd <[hidden email]
>>>>>>> <http:///user/SendEmail.jtp?type=node&node=5183884&i=0>> wrote:
>>>>>>> On Tue, Jan 27, 2015 at 11:17 AM, Nicolas Cadieux <[hidden email]
>>>>>>> <http:///user/SendEmail.jtp?type=node&node=5183884&i=1>> wrote:
>>>>>>> Hi,
>>>>>>> Personally this is what I would do.
>>>>>>> Completely purges Qgis from your system. (Delete plugin
>>>>>>> directories, AND the Qgis registry keys.) Reboot.
>>>>>>> I would install Qgis 2.6.1 using the OSGEO install.
>>>>>>> I followed these steps. My install was already done via osge064w and
>>>>>>> uninstalling was a little tricky.
>>>>>>> I removed the directories and the registry entries.
>>>>>>> I then reinstalled QGIS via the express installer.
>>>>>>> QGIS wouldn't start giving an error about jvm.dll missing from my
>>>>>>> computer.
>>>>>>> I manually selected the java install via the advanced option, jvm is
>>>>>>> installed and in a subfolder in C:\osgeo4w64
>>>>>>> I suspect it's a path problem, working on this.
>>>>>>> I would make sure that all mapped drive are properly remapped with
>>>>>>> the proper passwords, I would install the open layer plugin and wms or
>>>>>>> other data servers. Make sure the symbols are reinstalled if you had new
>>>>>>> ones and also make sure the .svg symbol images are well mapped.
>>>>>>> If the problem persists, I would repurge Qgis, install and older
>>>>>>> version and try again.
>>>>>>> Finally, i would then start looking at the project files with a text
>>>>>>> editor to try to understand the problem. I is likely the crash is cause by
>>>>>>> a layer that cannot be opened and that this layer depends on a plugin like
>>>>>>> openlayer, a mapped drive, wms servers... That would be my guess.
>>>>>>> Téléphone: <a href="tel:514.381.5112" value="+15143815112"
>>>>>>> target="_blank">514.381.5112 Fax: <a href="tel:514.381.4995"
>>>>>>> value="+15143814995" target="_blank">514.381.4995
>>>>>>> Le 2015-01-26 18:16, "Matt Boyd [via OSGeo.org]" <[hidden email]
>>>>>>> <http:///user/SendEmail.jtp?type=node&node=5183862&i=0>> a écrit :
>>>>>>> Thanks Lene,
>>>>>>> I tried that on a 3 projects this morning with no change to the
>>>>>>> behaviour. I've had 2.6.1 for a while now and these projects opened in that
>>>>>>> early last week.
>>>>>>> I've also tried loading older projects that are still in 2.0, 2.2,
>>>>>>> and 2.4 format and the same thing happens.
>>>>>>> Most of my projects are on a network drive and I've managed to get a
>>>>>>> step further by copying those project files to a local drive. I then get
>>>>>>> the "handle bad layers" dialog, then qgis crashes. I need to dig a little
>>>>>>> to see if this is a problem in case someone has moved some of the layers
>>>>>>> the dialog is referring to but this hasn't caused a crash before.
>>>>>>> Is this behaviour logged anywhere?
>>>>>>> Thanks
>>>>>>> Mat
>>>>>>> On Tue, Jan 27, 2015 at 9:58 AM, Lene Fischer <[hidden email]
>>>>>>> <http:///user/SendEmail.jtp?type=node&node=5183855&i=0>> wrote:
>>>>>>> Please first update to 2.6.1.
>>>>>>> If you have your crashed projects – you also have projects named
>>>>>>> with a .qgs~. Rename this project and delete the ~ and open it as usual.
>>>>>>> A lot of my students had the same problem last week – but only the
>>>>>>> ones who had forgotten to update to 2.6.1
>>>>>>> Hope this can help you.
>>>>>>> Regards
>>>>>>> *Lene Fischer*
>>>>>>> Associate Professor
>>>>>>> *Department of Geosciences and Natural Resource Management*
>>>>>>> University of Copenhagen
>>>>>>> MOB <a href="tel:%2B45%2040115084" value="<a
>>>>>>> href="tel:%2B4540115084" value="+4540115084" target="_blank">
>>>>>>> +4540115084" target="_blank"><a href="tel:%2B45%2040115084" value="
>>>>>>> +4540115084" target="_blank">+45 40115084
>>>>>>> [hidden email]
>>>>>>> <http:///user/SendEmail.jtp?type=node&node=5183855&i=1>
>>>>>>> [image: cid:image001.gif at 01D03029.2F3EC6A0]
>>>>>>> *Fra:* [hidden email]
>>>>>>> <http:///user/SendEmail.jtp?type=node&node=5183855&i=2> [mailto:[hidden
>>>>>>> email] <http:///user/SendEmail.jtp?type=node&node=5183855&i=3>] *På
>>>>>>> vegne af *Matt Boyd
>>>>>>> *Sendt:* 26. januar 2015 23:29
>>>>>>> *Til:* qgis-user
>>>>>>> *Emne:* [Qgis-user] Fwd: QGIS crash on loading projects
>>>>>>> Just a bump to this question, does anyone know how to enable logging
>>>>>>> or find the log file? I really don't want to have to re create all my
>>>>>>> project files and I can't get any of the my old projects to open.
>>>>>>> On Fri, Jan 23, 2015 at 3:09 PM, Matt Boyd <[hidden email]
>>>>>>> <http:///user/SendEmail.jtp?type=node&node=5183855&i=4>> wrote:
>>>>>>> On Fri, Jan 23, 2015 at 2:58 PM, Nicolas Cadieux <[hidden email]
>>>>>>> <http:///user/SendEmail.jtp?type=node&node=5183855&i=5>> wrote:
>>>>>>> Hi,
>>>>>>> If you had and "openlayer" opened (like google earth or bing map),
>>>>>>> but but did not reinstall the plugin, it can crash. Try installing that
>>>>>>> plugin and see what happens...
>>>>>>> Nope, that doesn't help.
>>>>>>> Téléphone: <a href="tel:<a href="tel:514.381.5112" value="
>>>>>>> +15143815112" target="_blank">514.381.5112" target="_blank"><a
>>>>>>> href="tel:514.381.5112" value="+15143815112" target="_blank">
>>>>>>> 514.381.5112 Fax: <a href="tel:<a href="tel:514.381.4995" value="
>>>>>>> +15143814995" target="_blank">514.381.4995" target="_blank"> <a
>>>>>>> href="tel:514.381.4995" value="+15143814995" target="_blank">
>>>>>>> 514.381.4995
>>>>>>> Le 2015-01-22 22:46, "Matt Boyd [via OSGeo.org]" <[hidden email]
>>>>>>> <http://user/SendEmail.jtp?type=node&node=5183270&i=0>> a écrit :
>>>>>>> woops, forgot,
>>>>>>> windows 7 64 bit,
>>>>>>> qgis 2.6 installed via osgeo4w64
>>>>>>> On Fri, Jan 23, 2015 at 2:45 PM, Matt Boyd <[hidden email]
>>>>>>> <http://user/SendEmail.jtp?type=node&node=5183269&i=0>> wrote:
>>>>>>> Hi QGISers,
>>>>>>> for some reason today I can't load saved QGIS projects. QGIS crashes
>>>>>>> at abour 95% loaded with no information in the notification about why.
>>>>>>> I've tried reinstall from osgeo4w64, reboot, start from command
>>>>>>> line, disabling all plugins.
>>>>>>> Where's the log file kept and is there a way to enable logging from
>>>>>>> the osgeo cl window in windows 7?
>>>>>>> About the only thing that's different today is a few updates, one of
>>>>>>> them being a .NET windows update.
>>>>>>> Thanks
>>>>>>> Matt
>>>>>>> _______________________________________________
>>>>>>> Qgis-user mailing list
>>>>>>> [hidden email]
>>>>>>> <http://user/SendEmail.jtp?type=node&node=5183269&i=1>
>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>>> *If you reply to this email, your message will be added to the
>>>>>>> discussion below:*
>>>>>>> http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183269.html
>>>>>>> To start a new topic under Quantum GIS - User, email [hidden email]
>>>>>>> <http://user/SendEmail.jtp?type=node&node=5183270&i=1>
>>>>>>> To unsubscribe from Quantum GIS - User, click here.
>>>>>>> NAML
>>>>>>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
>>>>>>> View this message in context: Re: QGIS crash on loading projects
>>>>>>> <http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183270.html>
>>>>>>> Sent from the Quantum GIS - User mailing list archive
>>>>>>> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html>
>>>>>>> at Nabble.com.
>>>>>>> [hidden email]
>>>>>>> <http:///user/SendEmail.jtp?type=node&node=5183855&i=6>
>>>>>>> [hidden email]
>>>>>>> <http:///user/SendEmail.jtp?type=node&node=5183855&i=7>
>>>>>>> discussion below:
>>>>>>> http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183855.html
>>>>>>> <http:///user/SendEmail.jtp?type=node&node=5183862&i=1>
>>>>>>> NAML
>>>>>>> View this message in context: Re: Fwd: QGIS crash on loading
>>>>>>> projects
>>>>>>> <http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183862.html>
>>>>>>> at Nabble.com.
>>>>>>> [hidden email]
>>>>>>> <http:///user/SendEmail.jtp?type=node&node=5183884&i=2>
>>>>>>> [hidden email]
>>>>>>> <http:///user/SendEmail.jtp?type=node&node=5183884&i=3>
>>>>>>> discussion below:
>>>>>>> http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183884.html
>>>>>>> <http:///user/SendEmail.jtp?type=node&node=5183947&i=1>
>>>>>>> NAML
>>>>>>> projects
>>>>>>> <http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183947.html>
>>>>>>> at Nabble.com.
>>>>>>> Qgis-user at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150129/9416cbf3/attachment.html>
