[Qgis-user] Unable to add values to text string attributes
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Fri Jan 30 19:34:25 PST 2015
Welcome on board ;)
about the second question: Try the CadInput plugin.
Cheers
Bernd
Am 30.01.2015, 15:52 Uhr, schrieb Michael Grosberg
<grosberg.michael at gmail.com>:
> so, umm, hello, first time here.
> First of all, if any of the developers sees this - it's a wonderfull tool
> and a joy to use. Now, my question: I have a vector layer (ESRI
> shapefile)
> and I'm trying to fill some values. numerical values - no problem. I
> select
> some points (this is a point file), type the value I want, press "update
> all"
> and the column is filled with the value. But I tried the same with a text
> string (I created a new column and set it to type "string", made it
> 64 characters long to be safe), and it doesn't seem to work. after
> creation,
> the entire column has the value "null", but try as I might to enter a
> value
> and press "update all", this does nothing. If I do the same using a digit
> (and remember, this is a string attribute!), that DOES work for some
> reason.
> Any ideas what's going on? I've just tested it at home and the same
> problem
> exists, so it's not just my work PC.
> Oh, and another question, although I'm pretty sure the answer is no:
> I need to outline building outlines, which I currently do using other
> apps.
> But I'd love to switch to working with Qgis fulltime.
> Does QGIS have tools / plugins to help with drawing orthogonal shapes?
> I'm thinking about something that would let me draw one line freehand and
> then the rest of the lines would be constrained to be parallel or
> orthogonal
> to the first line. Alternatively something that would take a
> freehand-drawn
> polygon and straighten it.
> Qgis-user mailing list
Bernd Vogelgesang
Siedlerstraße 2
91083 Baiersdorf/Igelsdorf
Tel: 09133-825374
