[Qgis-user] Unable to add values to text string attributes
Lene Fischer lfi at ign.ku.dk
Fri Jan 30 19:45:21 PST 2015
http://www.catais.org/qgis/cadtools/
Rectangles Ovals Digitizing
https://github.com/narimanInrap/ArcheoCAD/blob/master/README.md
https://github.com/olivierdalang/CadInput
https://github.com/lbartoletti/CADDigitize
Regards
Lene Fischer
Associate Professor
Department of Geosciences and Natural Resource Management
University of Copenhagen
MOB +45 40115084
lfi at ign.ku.dk
-----Oprindelig meddelelse-----
Fra: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] På vegne af Michael Grosberg
Sendt: 30. januar 2015 15:53
Til: qgis-user at lists.osgeo.org
Emne: [Qgis-user] Unable to add values to text string attributes
so, umm, hello, first time here.
First of all, if any of the developers sees this - it's a wonderfull tool and a joy to use. Now, my question: I have a vector layer (ESRI shapefile) and I'm trying to fill some values. numerical values - no problem. I select some points (this is a point file), type the value I want, press "update all"
and the column is filled with the value. But I tried the same with a text string (I created a new column and set it to type "string", made it
64 characters long to be safe), and it doesn't seem to work. after creation, the entire column has the value "null", but try as I might to enter a value and press "update all", this does nothing. If I do the same using a digit (and remember, this is a string attribute!), that DOES work for some reason.
Any ideas what's going on? I've just tested it at home and the same problem exists, so it's not just my work PC.
Oh, and another question, although I'm pretty sure the answer is no:
I need to outline building outlines, which I currently do using other apps.
But I'd love to switch to working with Qgis fulltime.
Does QGIS have tools / plugins to help with drawing orthogonal shapes?
I'm thinking about something that would let me draw one line freehand and then the rest of the lines would be constrained to be parallel or orthogonal to the first line. Alternatively something that would take a freehand-drawn polygon and straighten it.
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
