[Qgis-user] R: extracting the starting point and end point from a linear geometry
DelazJ
delazj at gmail.com
Wed Jul 1 10:00:57 PDT 2015
You can use QChainage plugin to generate a shapefile with only start and
end points. All you have to do is to set, in Advanced tab, the "divide
feature into" option to 1.
Regards,
2015-07-01 17:01 GMT+02:00 CONTI Tonino <t.conti at comune.jesi.an.it>:
> THANKS RICHARD.
> DO I HAVE TO SELECT THE MAXIMUM AND MINIMUM VALUE FOR EACH ELEMENT AND
> DELETE THE OTHERS.
> YOU KNOW IF THERE IS A FUNCTION SELECTING THE FIRST AND LAST POINT OF EACH
> ITEM?
> TANKS
> TONINO
> Tonino Conti
> Comune di Jesi
> Sistema Informativo Territoriale
> Tel 0731538312 - fax 0731538513
> www.comune.jesi.an.it/sit
> ________________________________________
> Da: Richard McDonnell [richard.mcdonnell at opw.ie]
> Inviato: martedì 30 giugno 2015 16.43
> A: CONTI Tonino
> Cc: qgis-user at lists.osgeo.org
> Oggetto: Re: [Qgis-user] extracting the starting point and end point from
> a linear geometry
> Tonino,
> From the toolbar...Vector, Geometry Tools, Extract Nodes.
> This I think should help!
> Regards,
> Richard McDonnell
> OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
> OPW - Looking to the future - Caring for the past
> Email Disclaimer: http://www.opw.ie/en/disclaimer/
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150701/48d73395/attachment.html>
