[Qgis-user] Windows only, QGIS geoprocessing path bug?
Brent Wood
pcreso at pcreso.com
Fri Jul 3 18:35:36 PDT 2015
That seems to be the path to scripts, not the binary. All was set up OK in QGIS, but it uses system, not user path (Windows has 2 PATH environment variables)
Adding the R bin folder to the Windows user (not system) PATH variable & QGIS works fine.
Thanks
Brent Wood
From: Bo Victor Thomsen <bo.victor.thomsen at gmail.com>
To: qgis-user at lists.osgeo.org
Sent: Thursday, July 2, 2015 5:54 PM
Subject: Re: [Qgis-user] Windows only, QGIS geoprocessing path bug?
Is the path to the R binaries defined in menu "Processing" --> "Options", leaf "Providers" --> "R scripts" --> "R scripts folder" (using the "8.3" method of defining filenames, IIRC) ? And is R activated (Checkbox in the same branch) ?
Regards
Bo Victor Thomsen
AestasGIS
Denmark
On 01-07-2015 23:47, Brent Wood wrote:
I have a problem with in-house IT security & QGIS geoprocessing under Windows.
I'm trying to use R from within QGIS processing toolkit. The path to the R binaries is in the system path, but not my personal path, & I do not have permissions to change my path on this laptop.
I can run R from a terminal command line, but R is not found in QGIS. I believe this is because QGIS is checking in the user path, but ignoring the system path environment variables, so fails to find R.
I realise this is a problem created by IT security policies, rather than strictly a QGIS issue, but still feel QGIS should be checking both paths to locate external executable files.
Is it reasonable to file a bug for this?
Thanks
Brent Wood
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150704/2ccab90e/attachment.html>
