[Qgis-user] Windows only, QGIS geoprocessing path bug?
Bo Victor Thomsen
bo.victor.thomsen at gmail.com
Wed Jul 1 22:54:08 PDT 2015
Is the path to the R binaries defined in menu "Processing" -->
"Options", leaf "Providers" --> "R scripts" --> "R scripts folder"
(using the "8.3" method of defining filenames, IIRC) ? And is R
activated (Checkbox in the same branch) ?
Regards
Bo Victor Thomsen
AestasGIS
Denmark
On 01-07-2015 23:47, Brent Wood wrote:
> Hi,
> I have a problem with in-house IT security & QGIS geoprocessing under
> Windows.
> I'm trying to use R from within QGIS processing toolkit. The path to
> the R binaries is in the system path, but not my personal path, & I do
> not have permissions to change my path on this laptop.
> I can run R from a terminal command line, but R is not found in QGIS.
> I believe this is because QGIS is checking in the user path, but
> ignoring the system path environment variables, so fails to find R.
> I realise this is a problem created by IT security policies, rather
> than strictly a QGIS issue, but still feel QGIS should be checking
> both paths to locate external executable files.
> Is it reasonable to file a bug for this?
> Thanks
> Brent Wood
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150702/d315811d/attachment.html>
