[Qgis-user] Google Satellite and Measure line tool wrong results
    Nicolas Cadieux
    nicolas.cadieux at archeotec.ca
    Sun Jul  5 17:48:51 PDT 2015
I guess you are using the open layer plugin.  If so, Google layer go all funny on you if you zoom too much.  Vectorize a line in a shp file and see if the background moves.  If most likely will. If so, the problem is not with the measuring tool but with the Google layer.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112  Fax: 514.381.4995
www.archeotec.ca
On Jul 5, 2015 19:24, "Marco-5 [via OSGeo.org]" <ml-node+s1560n5214367h38 at n6.nabble.com> wrote:
	Hello all.
I just noticed that the "Measure line" tool is returning a distance
measurement that is dependent from the zoom level when I'm using the
Google satellite plugin. (increasing the zoom level results in a shorter
distance)
This is of course wrong, and the question is whether or not this could
be related to my setup or it is just a bug.
Tnx for help in advance.
Marco
QGIS version    2.9.0-Master               QGIS code revision    exported
Compiled against Qt    4.8.6               Running against Qt    4.8.6
Compiled against GDAL/OGR    1.11.2        Running against GDAL/OGR
1.11.2
Compiled against GEOS    3.4.2-CAPI-1.8.2  Running against GEOS
3.4.2-CAPI-1.8.2 r3921
PostgreSQL Client Version    9.3.6         SpatiaLite Version    4.2.0
QWT Version    5.2.3                       PROJ.4 Version    491
QScintilla2 Version    2.8.2
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/Google-Satellite-and-Measure-line-tool-wrong-results-tp5214367.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Google-Satellite-and-Measure-line-tool-wrong-results-tp5214367p5214372.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150705/46ec172e/attachment.html>
