[Qgis-user] line in dem from max to min
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Tue Jul 7 07:20:58 PDT 2015
I would have a column ID each polygon or multipolygone with a unique name. I would then densify the geometry to create new vertex along the line then extract these vertex to a point layer. I would then use the point value plugin to extract the value of the DEM for each point and then use a group statistic (grouping with the polygon name field) to get the min and max value for each object.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112 Fax: 514.381.4995
www.archeotec.ca
On Jul 7, 2015 7:50 AM, "v.botz [via OSGeo.org]" <ml-node+s1560n5214619h50 at n6.nabble.com> wrote:
i have some geometrys (multipolygon) and a dem (digital elevation model)
-> I need a line from the max value to the lowest value of the dem, for every multipolygon
is qgis a tool i could use - or do i need PostGIS ?
how could i realize this problem ??
any ideas? THANKS
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/line-in-dem-from-max-to-min-tp5214619.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/line-in-dem-from-max-to-min-tp5214619p5214670.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150707/513ed1f7/attachment.html>
