[Qgis-user] QGIS 2.8.2 GPS Tools and Garmin USB Connection
Lene Fischer
lfi at ign.ku.dk
Fri Jul 10 05:35:41 PDT 2015
Hi Antonio,
You can open a GPX- file as any other vector file. Just remember to choose the extension .GPX
The plugin is not needed to open.
Regards
Lene Fischer
Associate Professor
Department of Geosciences and Natural Resource Management
University of Copenhagen
MOB +45 40115084
lfi at ign.ku.dk<mailto:lfi at ign.ku.dk>
[cid:image001.gif at 01D03029.2F3EC6A0]
Fra: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] På vegne af Antonio Di Marco
Sendt: 9. juli 2015 16:35
Til: qgis-user at lists.osgeo.org
Emne: [Qgis-user] QGIS 2.8.2 GPS Tools and Garmin USB Connection
In QGIS 2.8.2 I couldn't download my Garmin GPS waypoints through Vector -- GPS Tools menu under an USB connection.
The device has this Command line under "Waypoint download":
%babel -w -i garmin -o gpx "%in" "%out"
I tried also this line: gpsbabel -w -i garmin -o gpx "%in" "%out"
In both cases I get this message:
Layer is not valid: The layer xxxx.gpx?type=waypoint is not a valid layer and can not be added to the map
I need an usb connection not a serial one via COM1
To verify that was not a driver trouble or something else I tried to gat the waypoints via GPSBABEL and everything is ok
Any answer will be very much appreciated
Antonio Di Marco
ARPAT (Agenzia Regionale per la Protezione Ambientale della Toscana)
Direzione tecnica - Settore SIRA (Sistema Informativo Regionale Ambientale)
Via N. Porpora, 22
50144 Firenze
Tel.: +39-055-3206416 Fax: +39-055-3206324
email: antonio.dimarco at arpat.toscana.it<mailto:antonio.dimarco at arpat.toscana.it>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150710/6dadccf6/attachment.html>
Type: image/gif
Desc: image001.gif
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150710/6dadccf6/attachment.gif>
